Crack output cap as preamp
Ritchie · 7512
Offline Ritchie
on: October 11, 2013, 01:27:25 AM
I am using my crack as a preamp, therefore I'm able to lower the output cap size depending on my amps input impedance.
If lowering the output cap should I also be increasing the output resistor?
Ritchie
Ritchie M.
crack/speedball as preamp,linn lp12 w/radikal/keel/urika phono, linn majik 4100 active monoblocks,linn majik isobarik speakers(active).
Reply #1 on: October 11, 2013, 02:14:10 AM
Ritchie,
You have to consider the parallel combination of the amplifier's input impedance and the output resistor.  Calculate the parallel equivalent and insert into the equation:
Fo=1/2*(3.141)*R*C  (that is 1 divided by the product of the string on the bottom of the fraction.)
where:
Fo is the 3 dB down point
R is the calculated value
C is the intended coupling capacitance
Here are the rules:
Fo is what everybody calculates to, but it is flat a decade above that.  I.E. if you calculate Fo of 3 Hz it is flat at 30 Hz.
You can swap things around, swap C and Fo to solve for the capacitor value if you have decided on the the targeted flat frequency.
Resistor and capacitor values are nominal, you need to measure them to know what is really going to happen.
I hope this helps.
« Last Edit: October 11, 2013, 02:15:44 AM by Grainger49 »
Offline jimiclow
Reply #2 on: October 11, 2013, 02:18:28 AM
I've been planning to do this on my Crack too by tapping a 3.3-4.7uf Clarity cap before the electrolytic cap and add RCA connectors. I'll leave the phone jack alone.
If you remove the electrolytic cap and phone jack, I'd put a 100k-500k resistors at the RCA jacks.
SEX 2.1- Alps, Mundorf
Stock Crack
Schiit Asgard, Schiit Lyr
Technics SL1200mkII
Woo WA-6
Offline Ritchie
Reply #3 on: October 11, 2013, 02:49:21 AM
Thanks guys, my amps input impedance is 1.8k, so with the 2.5k resistor in the crack I'm looking at approx. 1k. I usually like to calculate my -3db point to 2hz so with the resultant 1k I would be looking at approx. 80uf. When going with higher quality film caps it can get very expensive.
I would like to use a much higher output resistor to keep my impedance closer to the amplifiers 1.8k so I can get away with 40-50uf.
Will going with a high value resistor on the output have any effect on the preceding circuit.
By the way the crack really surprised me as a preamp, sounds great especially driving a difficult load and long interconnects.
Ritchie
Ritchie M.
Offline jimiclow
Reply #4 on: October 11, 2013, 03:13:33 AM
That's a difficult load for a tube preamp. You can disregard my previous post.  :-[
Stock Crack
Technics SL1200mkII
Woo WA-6
Offline Ritchie
Reply #5 on: October 11, 2013, 03:26:11 AM
Yes it is a biamped set up which brings the impedance down, the crack circuit has no problem driving this load with the 6as7 cathode follower and the right size cap.
Ritchie M.
Offline jimiclow
Reply #6 on: October 11, 2013, 03:37:16 AM
What amp are you using?
Stock Crack
Technics SL1200mkII
Woo WA-6
Offline Ritchie
Reply #7 on: October 11, 2013, 04:15:15 AM
The amps are Linn Majik 4100 which are 4 channel amps with built in active crossovers. So with four channels in parallel the input impedance ends up at 1.8k.
I know a solid state pre may be a better match but I much prefer the sound of tube pre amps. I'm using the crack now and not noticing any hint of bass roll off.
Ritchie M.
Online Paul Birkeland
Reply #8 on: October 11, 2013, 04:52:33 AM
You could probably do 50uF (47uF) and a 3.3K resistor across the output.
So you are using 8 channels of amplification?  Or is each pair of channels driven by one half of the Crack?
If the Crack is only driving one 4100, then the amp will see about a 3.7K load. In this case a 15uF cap would work, and you could go with a 10K bleeder on the jack.
The suggestion to add dedicated RCA output jacks is a good one.  At some point, someone will plug their headphones into your Crack and draw some unfortunate conclusions.
Offline Ritchie
Reply #9 on: October 11, 2013, 05:08:34 AM
I am using two 4100's one per speaker as I have 4 way speakers. Each channel actively drives each driver. So the crack would be looking into approx. 1.8K per channel.
I will be using it as a dedicated preamp without the headphone jack. I was hoping to use 44uf output caps as I have four Mundorf supreme 22uf caps on hand. I will eventually just try them but wanted to get close with the math first and figure out the allowable output rrsistor.
Ritchie M.
Reply #10 on: October 11, 2013, 09:52:01 AM
It can be tested easily with some jumpers.  Go for it!  Let us know what you hear.  Then it will sound better when you solder them in.
Offline Ritchie
Reply #11 on: October 11, 2013, 03:04:18 PM
Ok I will give them a try, but can someone recommend the output resistor value when using 44uf output caps driving amplifiers with a 1.8k input impedance?
Ritchie M.
Reply #12 on: October 11, 2013, 03:16:26 PM
1M ohms will give flat response at 20 Hz.  The resistor is there to eliminate the DC that bleeds through the output capacitor at startup.  It would drive your amps wild if they have a good low frequency response (like to DC) but most amps just thump.  The answer is to turn on the amps 30 seconds after the Crack.
Offline Ritchie
Reply #13 on: October 11, 2013, 03:18:48 PM
Thanks Grainger.
Ritchie M.
Reply #14 on: October 11, 2013, 08:04:04 PM
Cap Calculator
That will help with the frequency response calculation.
A 1M Ohm Resistor and a 44uF cap will give you a crap ton of startup voltage, but very good frequency response.  As you go down in resistance at the output, you will reduce this startup transient.  If you go too low, it will begin to combine with the input impedance of the Linn amp and start messing with the frequency response.  I wouldn't go any higher than 5K with a 44uF cap.
