Voltage on C3 and D3
pvannest · 3972
Offline pvannest
on: October 26, 2013, 12:02:36 PM
Just wanted to double check...   The voltage I have on C3 is 4.05 Volts and D3 is 5.33 Volts.    D3 is a bit high as according to the manual it should be between 3.5 and 4.5 Volts..   I swapped the tubes and the voltage issue did not follow the tube.   It stayed the same on D3.
Any ideas and what are the ramifications?
Project RPM 1.3, Speed box, Acrylic Platter, Sound Smith upgraded Sumiko EVOIII  Eros, Beepre, Emotive XPA-2, Cambridge Azur 640C, Magneplanar 3.7i's, Dayton Audio Sub.
Reply #1 on: October 26, 2013, 03:16:01 PM
This isn't really a huge difference - there just needs to be sufficient voltage for the regulator to function.  How is your regulated high voltage?
Offline pvannest
Reply #2 on: October 27, 2013, 05:05:04 AM
The rest of the voltages were within spec.   However, since I do not know for sure which voltage you are asking about, which location would be the regulated high voltage?
Reply #3 on: October 27, 2013, 08:51:46 AM
6 and 11.
Offline pvannest
Reply #4 on: October 27, 2013, 11:06:47 AM
6 is 144.8 Volts
and
11 is 145.2 volts
Reply #5 on: October 27, 2013, 11:20:33 AM
Looks great!
Offline pvannest
Reply #6 on: October 27, 2013, 11:52:42 AM
Sounds even better!   ;D
