Crossover inductors
vetmed · 2447
Offline vetmed
on: October 29, 2013, 03:23:30 PM
I have a couple of 4 mH iron core inductors. I need a couple of 2.2 mH inductors. Any ideas on how to transform one into the other? Keeping in mind that the only measuring instrument I have is a volt-ohm meter, no oscilloscopes or signal generators available here. TIA
Regards
   Robert Lees
Robert Lees
Offline johnsonad
Reply #1 on: October 29, 2013, 03:38:15 PM
You will need a meter that can measure inductors. To change the value you simply cut them down until you have the desired value.
Reply #2 on: October 29, 2013, 03:53:00 PM
Two 4mH inductors in parallel will give you 2.0mH, which may just be close enough.
Offline vetmed
Reply #3 on: October 29, 2013, 04:05:07 PM
There are meters for such things :o  I do need 2 so parallelling them up won't work.
   Robert Lees
Robert Lees
