(Don't know if finishing topics belong in this section, but it seems a better fit than any other.)
I finally got around to starting my very first build and have amazingly (for me) shown enough patience to do several days of experimentation & tweaking on both my wood base and mounting plate before starting assembly. While I'm really happy with what I got from the mounting plate and am ready to get started mounting components, my wood base looks at-best mediocre and I can't really figure out what I'm doing wrong.
Basically, my coats are drying up with a really uneven & gritty-looking shine on them, and on top of that there also appears to be really really small physical clumping of some sort - as if the surface was attracting visibly large/solid dust particles in the air as it dries (but I'm pretty sure that can't be the case as I'm doing this indoors in a large room kept immaculately clean). I'm using MinWax stain (I think oil-based?) & poly sealer (clear gloss) and am applying with two different size brushes, one large & one small. I've been really careful to even everything out with every coat on every panel, have been carefully sanding at every step as instructed on the MinWax products' directions, and have been allowing more-than-adequate drying times. I'm to the point where if I foul up another run, the sanding is going to start dulling the edges, so I need to get the next attempt right.
My only thought so far for potential improvement is switching from a brush to a rag, at least for the stain, in case the brush is laying it on too thick or is somehow clumping / otherwise gathering particles that are in-turn getting transferred to the wood. Other than that, I'm basically at a loss. The part that really bothers me is what it looks like after the poly dries, because it's just so far from what I thought it should look like as a "gloss" sealer. I figure that even if the staining step isn't perfect, the sealer should at least be giving me a respectable, smooth sheen, but it just isn't. I doubt that going at that step with a rag would improve anything, that is again unless the brush is what's contaminating or overdoing it on that final coat.
Anybody else have experience with addressing problems like these that they can share? I'm may not be blessed with the wood-working prowess of Ron Swanson, but this shouldn't be this hard considering the time & care I'm putting into it.
