Calculating SPL from S.E.X.
Loquah · 4209
Offline Loquah
  • Accidental Tube Addict
    • Passion For Sound
on: November 03, 2013, 01:13:08 PM
Can anyone tell me the approximate wattage produced from the S.E.X. wired on the 4 ohm taps and driving a 600ohm load?
Reply #1 on: November 03, 2013, 02:52:56 PM
See post below for corrected numbers!!
"Twinkle, twinkle, little star;
power equals I-squared R"
so 2 watts equals current squared times 4, hence current is 1 amp into 4 ohms.
Ohm's law says voltage equals current times resistance, so 4 volts across the output.
Ohms law, second variant, says current equals voltage divided by resistance, so 0.006666 amps into 600 ohms.
Consult the stars again, to get 0.02666 watts, or 26.7mW into the 600 ohm cans.
« Last Edit: November 04, 2013, 12:31:55 PM by Paul Joppa »
Offline Loquah
    • Passion For Sound
Reply #2 on: November 03, 2013, 03:14:50 PM
Thanks Paul.
Missing links for me was knowing that the 2 ohms came out prior to the OTs and that the 4 ohm taps are named thus for their impedance rather than what they match up with speaker-wise.  :-[
Your answer is extremely helpful and informative, thank you!
Offline Loquah
    • Passion For Sound
Reply #3 on: November 03, 2013, 03:18:44 PM
By the way, does this mean that the output impedance of the S.E.X. is equal to the OT tap ratings? (4 / 8 / 16 or 32?)
Reply #4 on: November 03, 2013, 03:42:43 PM
Nope.
The 4/8/16/32 ohm taps are designed to feed the maximum available power to loads of 4/8/16/32 ohms, respectively. The actual source impedance looking back intot he outputs is somewhere between 1/3 and 1/2 of the tap's nominal impedance.
Offline Loquah
    • Passion For Sound
Reply #5 on: November 03, 2013, 07:12:44 PM
OK. Thanks Paul.
Reply #6 on: November 04, 2013, 08:16:20 AM
Paul,
1 squared times 4 = 2? Not following that...
Reply #7 on: November 04, 2013, 12:30:55 PM
Paul,
Sorry, that was pretty terse, and incorrect to boot! Try again:
so 2 watts equals current squared times 4 ohms, hence current squared is 1/2 and current is 0.707 amps.
Ohm's law says voltage equals current times resistance, so 2.83 volts across the output.
Ohms law, second variant, says current equals voltage divided by resistance, so 0.0047 amps into 600 ohms.
Consult the stars again, to get 0.0133 watts, or 13.3mW into the 600 ohm cans.
Offline Loquah
    • Passion For Sound
Reply #8 on: November 04, 2013, 01:04:45 PM
Equal parts thankful and embarrassed.
Thankful that the correct maths brought available power down (gives me more confidence that I am not accidentally shredding my ears) and embarrassed that I didn't look at the sums closely enough to realise the error. Blind trust anyone!?  :-[
Reply #9 on: November 04, 2013, 02:24:58 PM
Always trust the blind guy :D
Do I get a free BeePre for finding a PJ math error :-).
Reply #10 on: November 04, 2013, 02:32:32 PM
With apologies to Jim, I make so many math errors that even the blind guy finds them. Seriously though, there's much more to looking than just seeing, if you take my meaning ...  :^)
Reply #11 on: November 04, 2013, 02:35:57 PM
No apology needed! Hey, we all do it -- some more than others.
Reply #12 on: November 05, 2013, 04:39:46 AM
All of us gray haired Electrical guys seem to do that from time to time.
