bad tube?
azrockitman · 2541
Offline azrockitman
on: November 05, 2013, 04:30:58 PM
Well, my stereomour is not even technically well broken in but it seems that I'm reaching the conclusion that one of the tubes is bad/going bad.
I noticed severe volume discrepancy on the left channel tonight, and after checking all connections, and changing music sources, I thought I would try the simplest test and simply power it down and swap tubes.
Bingo, the right channel now is severely diminished.
Only possibility is failing tube, right?
Esoteric DV-50, Technics SL1200-M3D, B&K Phono 10 Preamp, Sumiko Blue Point Special Evo III, Bottlehead Stereomour, Orca's
Offline galyons
  • Geary Lyons
Reply #1 on: November 05, 2013, 05:32:13 PM
Yep! If the problem followed the tube, that's the likely culprit.
Cheers,
Geary
Offline jimiclow
Reply #2 on: November 06, 2013, 02:59:04 AM
Is it the stock Sovtek 2A3? I wonder if Doc has a warranty on it.
SEX 2.1- Alps, Mundorf
Stock Crack
Schiit Asgard, Schiit Lyr
Technics SL1200mkII
Woo WA-6
Offline azrockitman
Reply #3 on: November 06, 2013, 03:09:36 AM
Yes, it's one of the pair that came with the kit.
Offline Mike B
Reply #4 on: November 08, 2013, 05:00:58 PM
Mine were 3 db off right out of the box.
Replaced with a nice matched pair of EH Golds.  No more 3 dB.
