Speedball R&R - circular pads pulled off PCB. No big deal?
Downhome Upstate · 2010
Offline Downhome Upstate
Guess a couple of joints weren't well-heated when I removed wires from the Speedball boards.
On the side of the board where the wire used to be, the tiny circular pad pulled loose when I pulled the wire.  :-\
The traces to which the pads attached are okay (not delaminated).
Just keep going, or time to get new boards (and some components to match)?
"Too soon old;
   Too late schmart"
    The late Mr. Fox, Fox's Deli, Rochester, NY
Mike P.
Reply #1 on: November 13, 2013, 10:26:05 AM
If the pads are still attached to the traces you can try reattaching them to the board with a tiny dot of superglue. Otherwise be careful resoldering, it's easy to tear the pad from the trace.
