es347 · 4828
Any thoughts appreciated.
Since the markings on the IEC connector are molded in it's hard to imagine how they could be in the wrong place. Have you used your meter to trace where the voltage can be found and where it is missing? Is it present at the IEC terminals? Is the fuse installed? Is voltage present at the power switch? I guess you may have missed the contact number listed at the back of the manual and on our contact web page. It is 206-451-4275.
I went with a time delay GDC 1A fuse and it held. I must have been charging the caps or dealing with xfmr inrush,etc. Anyway I got things powered up and the large tube glowed but the little guy, the 12AU7 did not.
