soldering iron on the way out
aragorn723 · 22201
Offline aragorn723
on: November 19, 2013, 12:29:00 PM
Hi,
I've been working on putting together a quickie, and am on the last few steps, but have been having trouble with my soldering iron.  It is a Weller ML500MP, which is a small, butane powered unit.  It worked pretty well until last night, when the piezo ignition had trouble lighting.  It used to start right up, but now i'm lucky if it works at all.  Can anyone recommend a good soldering iron (maybe corded?) for this type of work?  The tip i have now is a pencil tip, and that works well, so i would like to stay with that, but am wondering what wattage to get, since it looks like the iron won't make it thru the rest of the Quickie build.  Thanks!
Dave
Offline galyons
  • Geary Lyons
Reply #1 on: November 19, 2013, 12:51:51 PM
I have used a Hakko 936 soldering station for over 5 years now.  It's been dropped, knocked off the bench and generally thrown about.  It never fails to work exactly as expected.  The current replacement model is the Hakko FX888D.  Mine is a black, utilitarian box with no temperature display.  The FX888D is neon hi-tek and sports a digital temperature gauge.  Price is under $100.
Here is the Amazon listing: http://tinyurl.com/k32lylx
Hakko site: http://www.hakko.com/english/products/hakko_fx888d.html
Gotta have a good iron!!!!
Cheers,
Geary
Offline aragorn723
Reply #2 on: November 19, 2013, 02:16:56 PM
Thanks for the idea..  I don't really want to spend that much, maybe $50 or less?  Not sure how much i'll be using a soldering iron when the kit is done.. Of course this kind of thing is addicting, so who knows  8)
Offline howardnair
Reply #3 on: November 22, 2013, 10:53:12 AM
Offline btrancho
    • Trancho Photography
Reply #4 on: November 22, 2013, 11:12:13 AM
http://www.circuitspecialists.com/soldering-stations
I've built a dac, several amps (including my Crack w/ Speedball), three sets of speakers, many interconnects, and a few headphone cables with one of the lower end stations and a selection of tips.  I'm sure a Hakko is better, but mine gets the job done.
Bob Trancho
Offline aragorn723
Reply #5 on: November 25, 2013, 04:56:36 PM
http://www.partsconnexion.com/solderingstat.html
this  should fit the bill
So the brand of this is Hakko?  I dont know the name, but mostly just need something reliable, and good temp control too.  Does it do a good job on soldering that needs a lot of heat, like RCAs and terminal strips?  Also, how about low temp stuff like pcbs?  Thanks,
Dave
Offline galyons
  • Geary Lyons
Reply #6 on: November 25, 2013, 05:00:53 PM
Dave
Looks much like my old Hakko 936.  Very good unit.  Excellent price.
Cheers,
Geary
Online Doc B.
Reply #7 on: November 26, 2013, 05:33:00 AM
That's a screamin deal! I think I paid that much for a used one a while ago.
Offline SteveH
Reply #8 on: November 26, 2013, 08:20:49 AM
I thought I'd posted this once before, but maybe not.  This is not a Hakko 936, it is a 'high quality replica'.  From the pcX web page:
"NOTE: The 936 model is no longer in production by Hakko. These units are high quality "replica" stations (1 year warranty). "
Not saying this isn't a good station because I don't know.  It's not a Hakko, even though it looks like the replacement tip may be.
Still might pick one up as a backup.
SteveH
Offline aragorn723
Reply #9 on: December 04, 2013, 05:23:07 AM
How about Amazon?  Are there any good ones there for about $50?
Offline coca
Reply #10 on: December 04, 2013, 10:00:36 AM
Pick one up. I did. It's a 936 knock off. I spend more than that on coffee in a month at the donut store.
Bernie.
Offline aragorn723
Offline galyons
  • Geary Lyons
Reply #12 on: December 04, 2013, 12:26:22 PM
Like this?
http://www.amazon.com/gp/aw/d/B000VINMRO/ref=pd_aw_sbs_3?pi=SL500_SS115
Looks like another Hakko knock off.  Hard to say in terms of quality. Looks similar to the unit that Parts Connexion is selling.
Offline aragorn723
Reply #13 on: December 12, 2013, 02:59:37 PM
Are Weller ones any good?  Its really time to bite the bullet-I finished the PJCCS but can't solder it into the Quickie yet  :P  So the general consensus is to get a soldering station though, because of temp control?  Thanks,
Dave
Reply #14 on: December 12, 2013, 05:01:42 PM
I am personally extremely happy with the Tenma temp-controlled solder station which my wife got for me several Christmases ago - I believe she consulted Doc B behind my back on that.
However, I should add that I did a LOT of soldering when young with a combination solder pencil/woodburning kit sourced from Radio Shack, probably in the early sixties when I was a teenager.  I'd use my dad's solder gun when I needed more heat.  Eventually (early seventies? late sixties?) I gave my father a new solder gun to replace the old one which by then I had dropped and broken several times, and took the patched-up old one for myself. I used that for decades; the original Paramour was built with it. It had two speeds, 100 watts and 300 watts IIRC, so I grew adept at switching it on and off to establish the temperature. The heated tip was pretty fat, probably 1/4 inch wide and with a curvature diameter about the same. Its great advantage was a pair of flashlight bulbs which came on when the heat was on, illuminating the work.
You do eventually get used to the tools you have, and learn to make them work. But there's no way I would go back to that beast!
