Stereomour with a Crack
ALL212 · 3490
Offline ALL212
on: November 20, 2013, 03:17:22 PM
I have a Crack.
Would like to run my Crack off of my Stereomour and here's my thought.
Piggy back the output of the selector switch to one set of the RCA "inputs" and use it as an output instead.  I could put another switch in to select Crack or speakers but instead I could just turn the volume of the Stereomour to 0 when playing headphones.
Any issues???  This involves no extra parts and one very easy rewire.
Aaron
Aaron Luebke
Offline vetmed
Reply #1 on: November 21, 2013, 05:32:49 AM
If you can live with only 2 sources then give it a try, I see no reason why it would not work. As for turning down the volume on the Stereomour there is no reason for it to be turned on when listening to phones, you are using an entirely passive part of the Stereomour and no power is needed to send the signal to your Crack. Just be prepared to deal with any grounding issues that may come up ;D
Robert Lees
Robert Lees
Offline ALL212
Reply #2 on: November 23, 2013, 12:08:28 PM
Well...heck.   I thought I already oversimplified it but this is even better!
Aaron Luebke
