Better Late than never; voltage problems...
marantzfan · 77003
Offline marantzfan
on: November 23, 2013, 05:47:16 AM
Last year when BH was doing a cyber Monday sale, I bought the Seduction with Upgrade kit and shortly after if got here I got it put together (except for the upgrade isn't installed yet).  I stopped at that point because my voltage readings were off and then a gnat flew by and here we are nearly a year later.
So, hopefully someone here can help me to figure out what I have wrong here so that I can get this phono pre singing along with my Stereomour.
Here area list of the resistances that are not within tolerance:
Terminal     Resistance    My Resistance
1                   *                4.1
2                   *                4.1
6                   *                3.5
9                   *                2.3
12                 *                330
15                 *                330
17              165-200          4.3k
19              175-210          4.3k
22              165-200          0
24              175-210          10
25                 *                 330
27                 *                 17
Couldn't get a reading at A3, B3, A8, B8
Here are a list of the voltages that are not within tolerance:
Terminal       Voltage      My Voltage
6                  6.5VDC        1.7VDC
9                  6.0VDC        1.3VDC
27,37             70VDC        134.4VDC, 134.4VDC
29,39             70VDC        132.0VDC, 132.0VDC
30,40             70VDC        131.0VDC, 131.0VDC
A1, B1            70VDC        130.0VDC, 130.0VDC
A3, B3           1.6VDC        168mv, 177mv
Also, the transformer seems to get very warm.  I didn't leave it powered up for very long, just long enough to get the voltage measurements.
I've visually checked and double checked my work and can't find anything suspicious.  Any help would be greatly appreciated.
Anthony
BeePre, Paramounts 1.1, Eros, Thorens TD-124/AudioMods Tonearm/Ortofon 2M Black, IFI Micro Idsd, HQPlayer,  Altec 604-8G Duplex/620 Cabinets/Markwart Crossovers
S.E.X. 2.1, AKG K701
Reply #1 on: November 23, 2013, 07:03:24 AM
Hello Anthony,
We are certainly still quite up for helping you with your Seduction!
There is a small cluster of 1N5818 didoes with a 1.2 Ohm resistor and a 10,000uF cap.  I believe you have a backwards diode there, as you're not getting anywhere near 6.3V.  This would also explain the hot power transformer.  It's also possible that the 10,000uF cap is in backwards, which would cause similar issues.
Once you get 6/9 to read around 6V, you'll get more reliable voltage readings elsewhere.
Offline marantzfan
Reply #2 on: November 23, 2013, 07:17:50 AM
Here is the diodes section.
Reply #3 on: November 23, 2013, 07:30:08 AM
Hmm, nothing wrong there.
How about pins 4/5 on each 9 pin socket?
Also, you can pull the tubes and repeat the voltage checks for the ~6V terminals, it should creep up a bit over what's specified.
I also see that you have 0 Ohms at terminal 22, can you double check that?  There is symmetry back there on those two strips, so 0 Ohms at 22 should indicate 0 Ohms at 17, but both of those are a mistake.  The bare buss wire should only touch terminal 16, maybe there's a short between 16 and 17?
Offline marantzfan
Reply #4 on: November 23, 2013, 07:51:54 AM
Blown fuse.  I see a trip to radio shack in my immediate future.  These are fast blo fuses right?
Reply #5 on: November 23, 2013, 08:00:46 AM
Slow blow 0.5A or fast blow 1A will work.
A blown fuse indicates a short (as we were discussing), a miswire, a backwards cap, or a backwards diode.
Offline marantzfan
Reply #6 on: November 23, 2013, 08:58:21 AM
Installed new 1am fast blow fuse and it shorts instantly at power up....  Hmm
Reply #7 on: November 23, 2013, 09:26:12 AM
Try disconnecting the power transformer leads that connect to the DC heater supply and fire it up again. If a fuse holds you know the short is in the heater circuit somewhere.
Offline marantzfan
Reply #8 on: November 23, 2013, 10:15:35 AM
Just to make sure I understand this correctly, should I disconnect the two transformer wires coming into terminals 1 and 2 then power up to see if the fuse holds?
Reply #9 on: November 23, 2013, 10:23:37 AM
Yes, that is what they are saying.  And tape the wires just to be safe.
Offline marantzfan
Reply #10 on: November 23, 2013, 11:19:39 AM
Ok, disconnected  transformer leads from terminals 1 and 2 and taped each to be sure.  Powered up and fuse blew instantly but also, cap between terminals 20 and 25  is bulging.  I verified that it is oriented correctly as well as the diodes underneath it..??
Bad transformer?
Reply #11 on: November 23, 2013, 01:19:43 PM
When they swell they are bad, probably open, but maybe shorted.  I posted a picture of one that came out of my air conditioner compressor a year ago.  The top was spherical.
The conclusion would be that the leads to T1 and T2 are ok, the high voltage supply is the problem.  Is that where the cap on T20 to T25 is?
Transformers are not often bad out of the box.  But if molested they can give up smoke.  You usually see smoke from them.  The fuse is there to save the transformer because it is the single most expensive component.
Offline marantzfan
Reply #12 on: November 23, 2013, 01:29:59 PM
Haven't seen any smoke yet...  I'm completely dumbfounded on this one.  Btw, I just noticed that the resistor under that cap looks like some of the ceramic coating got cooked off of it...?
I've been sooooo happy with my stereomour I just want to get this pre working so I can listen to records again.
Reply #13 on: November 23, 2013, 02:37:38 PM
I looked at my schematic.  T20 to T25 is the first high voltage capacitor.  There is no resistor from those two terminals but there is one from T25 to T15 (1k Ohm) and one from T15 to T14 (270k Ohm).  Which one is burned?
Offline marantzfan
Reply #14 on: November 23, 2013, 03:55:32 PM
Actually the resistor looks chipped not burnt; maybe I did that installing it.  It's on the corner of the resistor.  Also, the resistor doesn't connect to the burnt cap but the terminal next to it...
I'll snap a few pictures of this area when I get a chance.
