Recommended power supply electrolytic upgrade
Tom-Huffman · 3656
Offline Tom-Huffman
on: November 26, 2013, 12:52:08 PM
What is the best replacement upgrade?
Reply #1 on: November 26, 2013, 01:37:02 PM
You might be able to fit some Panasonic TS-ED's on the board, just be mindful of the case diameter.
Offline Daikini
Reply #2 on: November 26, 2013, 01:44:40 PM
Film caps!
The stock electrolytics are quite good. But film caps can have even lower effective series resistance.  But they are physically huge at 220 uF and 600v. You can use a choke in place of a resistor between the caps (clc instead of crc) to lower ripple enough that smaller (lower capacitance)caps make sense.
Having done this, I can say it sounds better to me than stock, but not by a great deal. It's subtle, and not the first place I'd spend my fancy cap money.
David Gray
Empire 208/Jelco 750d/Nagaoka mp300 -> Seduction -> Stereomour ->Klipsch Heresy IIs w/ dual Polk PSW10s
Sony CDP-CX235 -> Schiit OptiModi -> Sex 2.1 -> Madisound BK-12m/Hifiman HE400
Reply #3 on: November 26, 2013, 03:03:27 PM
Film caps are tough in a doubler supply, as those first stage caps need to be pretty beefy to keep the ripple reasonable.
Offline ALL212
Reply #4 on: November 26, 2013, 03:25:47 PM
I like Nichicon's - here's my yet to be implemented power supply board:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi905.photobucket.com%2Falbums%2Fac253%2Fall212212%2FDSC_1148_zps9b80ef3f.jpg&hash=09e7d6c8661cd3068b8aa0f2557c4c19225b30b5)
I sure hope I have them installed with correct polarity!  I really like the document where there is an entire page or two or three dedicated to "GO BACK AND CHECK!!".
Aaron Luebke
Reply #5 on: November 26, 2013, 03:32:39 PM
Yeah, the Nichicons are another good suggestion, and fairly available too.  I'd recommend modeling the power supply to triple check that the ripple current isn't too much for whatever is chosen.
« Last Edit: November 26, 2013, 06:51:47 PM by Caucasian Blackplate »
