newbie : wrong DC voltage T5 and T6.
altec604e · 6945
Offline altec604e
Reply #15 on: December 05, 2013, 08:29:04 AM
Cool !    ;)
I then have a fully operational Stereomour amplifier !
I did plug inn my Submissive controller today also, it worked fine too !
The sound : in one word : GREAT !
Thanks for all help!
Signal Source : Thorens TD 124 MkI / SME 3012 / Denon DL103
Setup : Quad 44 / Bottlehead Stereomour / Altec 604E in DIY 612C cabs
Reply #16 on: December 05, 2013, 10:20:44 AM
I think what Grainger is trying to say is that the power is the constant at each of the impedance settings.  The 4 Ohm tap gives 3.5 Watts into 4 Ohms, the 8 Ohm tap gives 3.5 Watts into 8 Ohms, etc.
When you use a 16 Ohm speaker on the 4 Ohm tap, you get less power out (hence your need for for cranking up the level a bit), but with that decrease in power comes a lower noise floor and a higher damping factor.
Offline altec604e
Reply #17 on: December 18, 2013, 09:45:28 PM
Hello all,
I have one more question :
1.  Can I use my Stereomour with only one of my Alter 604E speakers connected to one of the channels for some time ; or is this not a good idea ?
I have not finished building the second speaker cabinet.  And I do not have the time to finish it during christmas.
- altec604e
Reply #18 on: December 19, 2013, 06:42:32 AM
There Stereomour won't be bothered by one unloaded channel, go for it!
Offline altec604e
Reply #19 on: December 19, 2013, 05:59:46 PM
Yes!  Thanks for the input !
