Speedball Error..Did I ruin my crack :-\
ashneel · 3919
Offline ashneel
on: December 03, 2013, 12:14:44 AM
My stock crack was working fine. Yesterday I installed Speedball. Did the voltages check today..and boom. When taking the voltage check at terminal 3, it made some sparks and a pop noise. The led under the 12au7 and the one one the left side of the board are not lighting up. Here are my volatges (using a 240V transformer)
1    77V
2    160V
3    NA
4    160V
5    0V
6    1.8
7    101
8    0
9    50
10   0
11   0
12   0
13   180
14   0
15   180
16   0
19   70
20   0
21   195
A1       0
A2       0
A3       0.7
A4       0
A5        0
A6        98.1
A7        0
A8        1.56
A9         0
B1         98.6
B2         160
B3         116
B4          0
B5        160
B6         50
B7         0
B8         0
Can someone please help me
« Last Edit: December 03, 2013, 01:54:07 AM by ashneel »
Reply #1 on: December 03, 2013, 07:51:16 AM
You must've hit one of the adjacent terminals to terminal 3 (which is grounded, you can skip that next time).
I'd e-mail replacementparts(at)bottlehead(dot)com and ask for a new small green PC board and associated parts.  I suspect the LED's on the tube socket are fine.
To check this, you can swap your functional green PC board to the other side.
Offline ashneel
Reply #2 on: December 03, 2013, 07:44:02 PM
Thanks Paul. I've emailed Eileen. I'm so distraught I can't listen to my crack  :-\
Reply #3 on: December 04, 2013, 12:39:36 PM
At least you didn't burn anything. Then you might be saying "I think I can smell my Crack."
Offline ashneel
Reply #4 on: December 04, 2013, 07:05:20 PM
Doc ,you jinxed it  :'( !! exchanged the boards tried it again, a little smoke coming from the TRS jack's resistors I think..Well now I smell it
Tough feckin luck. reverting to stock seems the only option
« Last Edit: December 04, 2013, 07:10:44 PM by ashneel »
Offline ashneel
Reply #5 on: December 05, 2013, 02:58:00 AM
These are the pics of the Speedball
Reply #6 on: December 05, 2013, 03:46:57 AM
You can put the 22K resistors back and attempt to run the amp with only the larger Speedball board.
Frying the 2.49K resistors at the output would be very difficult to do, and would require other components to fail in a way that would be very noticeable.
Offline ashneel
Reply #7 on: December 05, 2013, 06:14:08 PM
Ok,I re-soldered the boards. Did the voltages check again. I have 6 readings wrong, out of which, 3 show half the recommended values. 2 LEDS are noy working: One on the left PC board ( didn't work when I swapped it to the right also) and one directly below the 12au7.Here are my readings:
Terminal
1- 75 (31)
2- 170 (163)
3-  0 (0)
4-  170 (163)
5-  75 (82)
6-  0 (0)
7-  100 (55)
8-  0 (0)
9-  100 (105)
10-  0 (0)
11-  0 (0)
12- 0 (0)
13- 170 (163)
14- 0 (0)
15-  185 (182)
A1-  75(81)
A2-  0(0)
A3-  1.56(1.5)
A4-  0(0)
A5-  0(0)
A6- 75(0)
A7- 0(0)
A8- 1.56(0.5)
A9- 0(0)
B1-  75(0)
B2-  170(163)
B3-  100(56)
B4-  75(82)
B5-  170(160)
B6-  100(105)
B7-  0(0)
B8-  0(0)
Are the LEDS dead or something else ain't working right? Someone please help  :-[
Reply #8 on: December 05, 2013, 06:19:31 PM
Offline ashneel
Reply #9 on: December 05, 2013, 07:28:56 PM
I'm sorry Paul I missed your earlier post. It seems one of the boards ain't working right.
I'll try to put the 22k resistors back and try again
Reply #10 on: December 06, 2013, 12:40:23 AM
To test the LEDs (all are oriented properly, the pictures help here) use your meter on Ohms, put the leads on the LEDs one way then swap the meter leads.  In one direction, probably black to the flat/silver band end and red to the other, you have a good chance of lighting them.  Check good ones then bad ones if the good ones light.
This verifies that they are not damaged.
BTW, in one direction you get a low resistance in the other you get a high resistance.
