Top Plate dimensions
JamieMcC · 5827
Offline JamieMcC
on: December 04, 2013, 01:05:05 AM
I would like to start building a case for the Quickie while waiting for it to arrive in the post.   Please could you confirm the exact top plate dimensions.
Cheers
Jamie
Reply #1 on: December 04, 2013, 05:54:15 AM
Edited:
As Dan has stated, somewhere else on the forum  .  .  .   the top plate dimensions are as exact as LASER cutters can be. (This plate is Acrylic)  So 6"X10" plus or minus a few thousandths of an inch.
Interestingly the product description still says they are Acrylic, (and they are).
« Last Edit: December 04, 2013, 07:49:36 AM by Grainger49 »
Offline JamieMcC
Reply #2 on: December 04, 2013, 06:25:02 AM
As Dan has stated, somewhere else on the forum  .  .  .   the top plate dimensions are as exact as LASER cutters can be.  So 6"X10" plus or minus a few thousandths of an inch.
Interestingly the product description still says they are Acrylic, not aluminum.
Thank you, the top plates are the same size as the Crack then which is super. I will make something of similar dimensions to the Cracks so I can swap enclosures around every now and then for a different look.
From your post the plates now shipping are aluminium correct?
« Last Edit: December 04, 2013, 06:26:44 AM by JamieMcC »
Reply #3 on: December 04, 2013, 06:32:01 AM
I make the Quickie and Fix panels in my garage, with a drill press...
They are cut by hand on a table saw, and they get a pass or two on an edge router to clean off the saw cut marks on the edges.
All of this is done by hand, so the Quickie plates can have some variations.  I'd say 10"x6", +/- 1/16".  Typically, I try to get them just a hair on the small side.
Offline JamieMcC
Reply #4 on: December 04, 2013, 06:44:00 AM
Ah ha its great to know I know who to curse when it doesn't fit   ;)
I can easily cut out the grooves to suit with the router after making up the enclosure.
Reply #5 on: December 04, 2013, 07:02:05 AM
Quickie and Fix are acrylic. Where is this coming from?
Offline JamieMcC
Reply #6 on: December 04, 2013, 07:24:49 AM
I am confused now as to which it does not really matter to me  but I can see some clarity is required!
« Last Edit: December 04, 2013, 07:28:20 AM by JamieMcC »
Reply #7 on: December 04, 2013, 07:33:06 AM
When in doubt, the person who packs the kits is going to be right about what goes in them 9.9999 times out of ten.
My answer stands:
Acrylic. Unequivocally acrylic. The product description says they are acrylic because it is describing a product.
My only question is where is this wrong information coming from?
Reply #8 on: December 04, 2013, 07:37:12 AM
This is coming from my faulty 64 YO memory.  I thought I had read that the Q was now a laser cut panel.  I guess I was wrong.  The one on the product page surely looks aluminum (I worked for ALCOA so I know what it looks like) but says Acrylic.
Reply #9 on: December 04, 2013, 07:40:29 AM
I'll see if I can talk the plastic supplier out of a "brushed aluminum" acrylic plate for your Fix ;)
Reply #10 on: December 04, 2013, 07:45:53 AM
Cool. I'm just trying to make sure wrong info isn't canonized somewhere.
The product shot is on a pearlized white acrylic base, FWIW.
Reply #11 on: December 04, 2013, 07:50:41 AM
Joshua,
When I post misinformation I go back and correct it.  See above.  Not everyone does that.
I really detest misinformation.
« Last Edit: December 04, 2013, 09:04:46 AM by Grainger49 »
Offline JamieMcC
Reply #12 on: December 04, 2013, 08:55:22 AM
Great all cleared up, its easy to get ones wires crossed.
To be honest its rather neat knowing who has hand made my panel and who has packed it for shipping.
Thanks guys
