Battery Sale!
Sonido · 14669
Offline Sonido
on: December 04, 2013, 08:34:57 PM
I'm loving the Quickie so far! Using it with Emotiva MiniX a-100 to HE-500 headphones.
Check out my impressions here: https://www.head-fi.org/t/551345/hifiman-he-500-he-as-in-high-end-impressions-and-feedback/9645#post_10035084
Anyways, I was hasty to buy batteries to power the baby up, I ended up spending $22 at the local pharmacy for a single set of batteries.
But I just saw this great battery sale that I wanted to share: Sony STAMINA PLUS Alkaline Batteries - http://www.woot.com/offers/sony-stamina-plus-batteries-5-sizes-1
$12.99 for a pack of 12 D cell or 9V.
« Last Edit: December 04, 2013, 09:13:16 PM by Sonido »
Offline Sonido
Reply #1 on: December 04, 2013, 08:57:13 PM
Speaking of batteries, does anyone know if the D cells and the 9V drain equally? Do I end up replacing all at once?
Offline corndog71
Reply #2 on: December 05, 2013, 02:43:17 AM
I think the D cells go faster.
Rob
Reply #3 on: December 05, 2013, 02:53:51 AM
I don't even own a Quickie but bought AA, AAA and 9V.
I get the daily Woot! and had been considering it anyway.  These are good prices.
Offline mortron
Reply #4 on: December 09, 2013, 06:29:13 PM
My four 6xAA batery packs cost me $8 and I got 48 AA for $10.... not sure how long its going to last... last I checked it was just about 34v after quite a few months IIRC. I have already had to swap out my D cells about a month or so ago. Ill never buy $$$ 9V batteries again. The cheap AA are too plentiful.
Reply #5 on: December 09, 2013, 07:48:18 PM
Based on the data sheets for the batteries, they should last about the same time, roughly 200 hours.
In the real world, it seems that batteries in perfect condition that might meet data sheet specs are pretty uncommon. I suspect @mortron has a good idea, in that AA's are so widely used, they are both cheaper per watt-hour, and probably fresher, than any other size. You can parallel a similar number, half for each tube, to get a similar-lasting filament battery. You may have to pay more for the battery holders than the Quickie though!
Reply #6 on: December 11, 2013, 07:33:29 AM
I've also found that the green and black batteries from R@dio Sh@ck will die rather immediately right after you start using them.  I used a fresh set of four in my Quickie for about 10 minutes, then pulled them out and set them on the counter to go do some tweaking to the circuit.  When I got around to putting them back in 3 weeks later, all four were completely dead.
Offline Sonido
Reply #7 on: December 13, 2013, 07:07:22 AM
Woot sale is back till 12/16!
https://tech.woot.com/plus/batteries-etc
Reply #8 on: December 13, 2013, 10:19:06 AM
I got my shipping notice this morning.
Reply #9 on: December 13, 2013, 05:27:00 PM
Any reason why nobody is using rechargeables?
Offline corndog71
Reply #10 on: December 14, 2013, 04:01:22 AM
I use them for the 36vdc.  Been wanting to get rechargeable D cells but they and the appropriate charger are expensive.
Rob
Offline STURMJ
Reply #11 on: December 14, 2013, 06:53:59 AM
I have rechargeable 9v(s) too.
Offline Sonido
Reply #12 on: December 14, 2013, 08:07:09 AM
I've heard rechargeables don't charge up to the max 1.5v or 9v. Might be okay if you have the PJCCS upgrade.
Reply #13 on: December 14, 2013, 09:12:27 AM
The tubes and the amp are designed around 1.25v and 30v, expecting a range of 1.0v-1.5v and 24v-36v over the battery life. So NiCd and NiMH at 1.20 volts/cell and not losing voltage as they drain are about perfect.
Offline Mike B
Reply #14 on: December 16, 2013, 05:09:15 PM
I ordered up (3) eight AA holders and am going to do the 24 piece AA conversion too.  They were not expensive.
http://www.tmart.com/8Pcs-AA-Cells-Battery-12V-Clip-Holder-Box-Case-Black_p127663.html?fixed_price=us_us&utm_source=base&utm_medium=organic&utm_term=88006383&utm_campaign=product&gclid=CLDB5-OwtrsCFTJo7AodOkMApQ
Good idea on the AA's, thanks!
