adding subwoofer out
charger · 2805
Offline charger
on: December 08, 2013, 01:51:44 AM
Is it possible to add a subwoofer out in the Q ? anyway is it possible to use a sub with the Q ?
Oppo 980H - PC - Arcam rDac- Bottlehead Quickie- Abletec ALC040 - Signal cables Atlas Element Integra-speakers cables Tellerium Q black-Martin Logan Motion 15
Reply #1 on: December 08, 2013, 02:00:20 AM
You could just use Y-adapters first to see how it sounds.  An additional output would be fine as long as there is no noise added in the wiring.
The FP III has two outputs.  It had a 1k Ohm resistor from the first output hot to the second output hot.  It adds isolation between the two loads.  But I would try the Y-adapters first.
