Speed ball error? Solved!
JamieMcC · 3507
Offline JamieMcC
on: December 12, 2013, 03:59:56 AM
Hi guys I have just added the Speedball and need a little help trouble shooting I have the UK 240 version.
All leds light up on both boards and octal sockets
The 6080 both filaments glow
The 12au7 gets warm but I could see no glow
Volts checks look ok except the following
at terminal 19 I have 82
at terminal 20 I have 0
I did knock the 220uf 250 v capacitor attached to 20 and 21 and wonder if I might have damaged it?
« Last Edit: December 12, 2013, 05:58:29 AM by JamieMcC »
Offline JamieMcC
Reply #1 on: December 12, 2013, 04:54:46 AM
I have tried reflowing solder joints on 20 and 21 upper and lower terminals. No change
Offline JamieMcC
Reply #2 on: December 12, 2013, 05:09:09 AM
OK I went through the sticky and noticed
"Here's a typo that managed to sneak in from an early version of the Crack manual due to a copy and paste error:
In the voltage check on page 29, Terminal 20 should read 0VDC and terminal 21 should read 206VDC. Terminal 19 is not a relevant measurement."
So after measuring terminal 21 which has 212 v its looking better
But I am still concerned as to why the 12au7 does not glow now?
« Last Edit: December 12, 2013, 06:27:21 AM by JamieMcC »
Offline JamieMcC
Reply #3 on: December 12, 2013, 05:26:19 AM
OK I swapped over the 12u7 I was testing with and replaced with a RCA Clear Top, switched off the lights and both filaments can now be seen glowing. Not if sure if everything is resolved as yet however the speedball and Crack are now up and running and I have music.
« Last Edit: December 12, 2013, 05:46:06 AM by JamieMcC »
Offline JamieMcC
Reply #4 on: December 12, 2013, 05:57:03 AM
I am pleased to confirm after some listening.
Speedball, it does what it says on the tin   :)
"Things get tighter and quicker, bass and midrange get cleaner and more dynamic sounding, and the background gets more quiet. As with all of our upgrade kits, the improvement is easily heard."
Cheers
Jamie
Edit it was tight but with a little pressure I did managed to fit the large speedball ball board  without having to remove the two capacitors that required bending back even though one was rather snuggly fitted to its rail.
« Last Edit: December 12, 2013, 06:37:54 AM by JamieMcC »
Reply #5 on: December 12, 2013, 07:53:47 AM
Jamie,
It comes in a Tin???
I had the same reaction to the C4S in my FP 2.
Offline JamieMcC
Reply #6 on: December 12, 2013, 08:25:43 AM
Jamie,
Ah its a British saying it generally means a product does exactly what it claims to do
 ie The product inside the tin does exactly what it says on the label on the outside.
Wiki
"It does exactly what it says on the tin" was originally an advertising slogan in the United Kingdom, which then became a common idiomatic phrase.[1][2] It colloquially means anything that is as it appears or claims to be without further explanation needed.
Reply #7 on: December 12, 2013, 09:14:44 AM
I needed the Tongue-In-Cheek Smiley face to go with that comment.
Offline JamieMcC
Reply #8 on: December 12, 2013, 11:07:47 AM
lol ;D
Reply #9 on: December 12, 2013, 04:42:08 PM
Hmm, a decorative tin might make for some fun product shots!
