Resistance Check Issue
chewychevy · 3951
Offline chewychevy
on: December 13, 2013, 09:10:44 PM
Hi Folks,
For terminal 19 and 22 I get ~220K Ohm reading instead of null. All the voltages check out. Tubes light up, LEDs light up and I was able to bias to 145V. Any ideas what the issue could be before I tear into it?
For 20 and 30 I occasionally get a 2M Ohm reading and then it nulls. I'm guessing this is the film capacitor trying to charge off the multimeter causing this?
Reply #1 on: December 14, 2013, 06:40:09 AM
The "*" in the manual is essentially anything not close to zero.
20 and 30 will indeed bounce around as the meter attempts to charge the 4uF cap.
