Reduction no sound
Nerfe · 4562
Offline Nerfe
on: December 25, 2013, 06:29:22 PM
Hi, I've being enjoying the reduction for a while, last day I decided to righten the RCA because they were somewhat loose,after i did there's no sound.
I already check the voltages and resistance and all are under tolerance, any idea what could have happened?
Thanks for the help
Offline fullheadofnothing
Reply #1 on: December 25, 2013, 06:39:13 PM
Sounds like you need to resolder the joints on the RCAs.
Reply #2 on: December 25, 2013, 07:31:35 PM
If the solder joints on the jacks are solid, measure the resistance across each jack (center pin to ground) to ensure that the jacks themselves aren't shorted.
Offline Nerfe
Reply #3 on: December 30, 2013, 04:08:47 PM
Thanks for the help,I checked the solder joints and they are solid and they are not shorted. There is just a humming if i turn all the volume up, any other ideas?
Thank you
Reply #4 on: December 30, 2013, 04:56:19 PM
Based upon your description the problem should be at the RCA jacks you tightened. Either something broke loose when it twisted or some wires crossed and shorted. If you don't see anything obvious try comparing the photos from the manual with your wiring. Something may show up that you haven't noticed yet.
