Screws too short
NishBtl · 2321
Offline NishBtl
on: January 05, 2014, 01:10:20 PM
I'm having some trouble installing the plate chokes and output transformers onto the chassis. It seems that the screws are just a little too short or the fiber shoulder washers are slightly too thick. Does anyone have any tips/tricks to get it to work?
Mark Nishibayashi - Glendale, CA
Equipment: Assortment of Blumenstein Audio Speakers (Maxima BiBs, Cobras, Orcas), AKG K601 headphones
Reply #1 on: January 05, 2014, 01:14:53 PM
It's OK to use 6-32 x 1/2" screws if the 3/8" ones aren't quite fitting.  (These are easily found at the local HW store)
Offline NishBtl
Reply #2 on: January 05, 2014, 02:04:45 PM
Haha. I guess that's easy enough.
Thanks.
Reply #3 on: January 05, 2014, 03:36:18 PM
Are you certain that the fiber shoulder washers are seated correctly, with the smaller end inside the hole? This is to ensure electrical isolation and hence important, but it's not always easy to make it happen. Check also for excess varnish on transformer mounting tabs.
