newbie voltage problem (B6 and T9 reads 0v) (Solved)
solion · 2176
Offline solion
on: January 07, 2014, 06:54:35 AM
Got the crack assembled. Resistance tested out good. T9 and B6 read 0v (should be 100v) while all the rest tested out OK (T7 B3 read ~110v). Voltage readings on other terminals were all within spec. I've checked socket orientation and it was correct. Both LED lit up on the 9 pin. Both tubes were glowing. All soldering joints seemed to be fine. Any suggestion? Thanks!
« Last Edit: January 13, 2014, 07:58:40 AM by solion »
Offline solion
Reply #1 on: January 13, 2014, 07:58:16 AM
Problem solved. It was the 6080 tube that has one channel not working. Although both filament were glowing fine, one of the cathode was not emitting. I ordered a Tung sol 5998 and plugged in and both channel works now.  I am sending back the old tube for a replacement as a backup. Thanks Paul for the help over the phone.
I then proceeded with the speedball upgrade and the improvement was quite significant.
It has been a fun process building it and the music coming out of the crack is simply stunning. ;D
Cheers!
Offline PZAPRTY
Reply #2 on: January 28, 2014, 08:13:00 PM
I've got the same problem. How did you go about troubleshooting to determine if the tube is bad? Against my better judgement I plugged in some headphones and only the right channel worked. Everything except for T9 and B6 are within ~15ish volts of what it should be.
