6080/6AS7 cuts out after about 3 minutes [solved]
Twodawgzz · 3747
Offline Twodawgzz
on: January 09, 2014, 11:50:37 AM
If I move it around a bit in its socket it sometimes comes back on for another 3 minutes or so.  Completed the build about a week ago, and nothing seemed to be amiss.  All resistances and voltages checked out, and the sound through headphones is great.
Any suggestions or words of wisdom?
« Last Edit: January 25, 2014, 08:04:52 AM by Caucasian Blackplate »
Reply #1 on: January 09, 2014, 12:00:47 PM
You have a bad heater pin connection. Resolder the wires connected to the heater pins, and try cleaning the tube pins with a scotchbrite pad.
Offline Twodawgzz
Reply #2 on: January 09, 2014, 12:11:49 PM
All right.  Will do.  Thanks.
Offline Twodawgzz
Reply #3 on: January 10, 2014, 09:08:55 AM
Problem not solved.
I unsoldered and carefully resoldered all heater pin connections and cleaned the tube pins.
When I turned the amp on, it took a good couple of minutes before the 6080/6AS7 glowed.  Listening to music through the amp, it then worked fine for about 7 minutes, and the tube then shut down (but not the 12AU7).
So what should I check next?
Reply #4 on: January 10, 2014, 09:16:40 AM
The next thing to do is check to see if there is actually voltage present at the tube pins when the tube is not glowing. That will determine if the tube is at fault or if the voltage is not getting to the tube socket. If, when the tube stops glowing, you can get it to glow again by rocking the tube in the socket a little, it's the socket or wiring and not the tube.
Reply #5 on: January 10, 2014, 11:33:02 AM
You might want to try snugging up the heater socket.  Bending it a little tighter.
Can't hurt, might help.
Offline Twodawgzz
Reply #6 on: January 17, 2014, 08:28:51 AM
Checked all and redid some solder joints.  6AS7 still not heating up.  Checked it with my Eico 667 Tube Tester and get absolutely no readings.  At the same time, it appears I have another problem.  While all voltages, etc., checked out immediately after the build, now I'm getting no voltage readings from Terminals 7, 9, B3, and B6.
Reply #7 on: January 17, 2014, 08:30:22 AM
Is the 6080 not glowing in the tube tester?
Offline Twodawgzz
Reply #8 on: January 17, 2014, 11:46:56 AM
Nope.
Offline Twodawgzz
Reply #9 on: January 18, 2014, 06:31:22 AM
Not glowing.
So Doc... what happens next?  Do you send me a replacement tube?  Does my comment about zero voltages make sense if the 6080 is dead... or is something else also happening?  I am your customer Walt Weiskopf, by the way, who ordered the Crack on Nov. 30, 2013, I believe.
Reply #10 on: January 18, 2014, 08:42:56 AM
Just to be sure, you can check the resistance of the heater, pins 7 & 8. should be pretty low...John
Offline Twodawgzz
Reply #11 on: January 25, 2014, 06:46:34 AM
Problem solved.  Output tube was bad.  With replacement 6080 the amp is now working fine and sounds unbelievably great!
Thanks Doc B!
