need help with resistor value
aragorn723 · 4951
Offline aragorn723
on: January 10, 2014, 03:22:21 PM
I have been thinking about tweaking the matching between the Quickie and my amp (Inter-M R500).  The output impedance of the amp is 10K, and the Quickie has the PJCCS.  What value resistor do I need for this, and where does it go on the Quickie?  The amp is turned way down because the gain of the Quickie is so high.  I would like to be able to turn the volume on the Quickie up more.  Thanks,
Dave
Reply #1 on: January 10, 2014, 05:09:35 PM
By output impedance, I assume you mean input impedance?  :^)
The pad goes at the input of the power amp.
Offline aragorn723
Reply #2 on: January 10, 2014, 05:27:25 PM
Yes, input impedance ::)  I'm guessing it goes on the signal (not ground) part of the rca?  How do you physically wire it, with a little box with rca jacks, and solder the resistors in the middle?  Also, what would be the best value for the resistor?  Thanks,
Dave
Reply #3 on: January 11, 2014, 02:23:47 AM
Dave,
What are you trying to do?  If you want to use the full range of the volume control on the Quickie, you need an attenuator at the amp's input.  The best place to do this is to use a pair of resistors for each input.
But there is no reason to match the Quickie's output impedance to the amp's input impedance.  The amp's input impedance should be at least 10 times greater than the output impedance of the Quickie to get the best sound.
Offline aragorn723
Reply #4 on: January 11, 2014, 07:27:23 AM
by matching impedance, i mean getting the input impedance of the amp to be 10 times greater than the output impedance of the Quickie.  How would you suggest hooking it up?
Reply #5 on: January 11, 2014, 08:46:30 AM
This is a separate issue from not being able to turn the Quickie up very much because the amplifier is so sensitive.
To decrease the sensitivity of an amplifier, you can add a pair of resistors at the input.  In your case, try a 47K resistor in series with the input and a 10K resistor to ground.  Here's a page with some decent photos: Amplifier Padding
Doing this will also increase the input impedance of your power amplifier.
Reply #6 on: January 11, 2014, 10:14:57 AM
You need to look inside your amplifier to see where the input resistance is now.  Many amplifiers have a resistor from the center conductor of the input RCA jack to the ground, or outer conductor of the input RCA jack.  Removing it and changing it to the needed resistance would work.
Others have the input resistor on a circuit board where the first stage of the amplifier is.  You can trace it through the input wires.
Reply #7 on: January 11, 2014, 10:19:00 AM
On the web I could only find specs for a version of this amp with balanced inputs. That makes the attenuator question more difficult, especially without a circuit diagram of the input.
Offline aragorn723
Reply #8 on: January 11, 2014, 02:37:28 PM
There are 2 versions of the amp out there- an R500, and R500 plus.  The one I have is the R500.  Not sure this will help, but here is the manual (the one at the bottom of the page).
http://www.manualslib.com/products/Inter-M-R-500-584310.html
I'm using the 1/4" jacks, but based on the manual it looks like both the 1/4" jacks and XLR are balanced??
« Last Edit: January 11, 2014, 02:52:55 PM by aragorn723 »
Offline aragorn723
Reply #9 on: January 11, 2014, 02:57:48 PM
Reply #10 on: January 17, 2014, 08:38:41 AM
I read the manual the same way - there is only a balanced input, of nominal 10K impedance.
According to the manual, there are input level controls on the amp. Turn them down, then you can turn up the Quickie controls.
Offline aragorn723
Reply #11 on: January 17, 2014, 10:07:29 AM
that's what I wound up doing, it improved the sound of the Quickie!  I get a more detailed sound, and better high end response as a result.  Is there a drawback to doing it this way vs. changing the input resistors?  The only one I can think of is volume, but i'm already getting enough of that (and my wife is too lol).  Thanks!
Dave
Reply #12 on: January 17, 2014, 02:05:44 PM
Looking at the block diagram, the only way it can be a problem is if the Quickie would overdrive the balanced input stage. If it's a balanced input for pro applications (as it is) then it should be able to handle at least +20dBu peaks, which is more signal than the Quickie is capable of generating. No problems!
