Voltage Check Problems [solved]
jarn221 · 4099
Offline jarn221
on: January 11, 2014, 05:23:09 PM
Hi all,
I've finished putting the Crack together.  Everything checks out perfect with resistance checks, but when it comes to voltage checks, it seems we have no voltage for any minus the two checks that expect a reading of 1.5 (we get 1.006 and .995 respectively).   The tubes glow when the unit is turned on, but no voltage besides those two exceptions.
If anyone has any suggestions, we would greatly appreciate it!  Happy to provide any further information that might be helpful to diagnose.  Really looking forward to getting this Crack running.
« Last Edit: January 13, 2014, 04:56:07 AM by jarn221 »
Reply #1 on: January 11, 2014, 05:24:26 PM
Please list all of the DC voltages that you have.  Are they all zero?
Offline jarn221
Reply #2 on: January 11, 2014, 05:35:55 PM
Thanks for your reply.  Yes, they are all zero, with exception to A4 and A8, which yielded 1.006 and .995 respectively.
Reply #3 on: January 12, 2014, 01:10:40 AM
What do the batteries read?  Try from one end to the other (they are all in series) rather taking each out and measuring.
My mistake this is a Crack, no batteries.
« Last Edit: January 12, 2014, 07:29:13 AM by Grainger49 »
Offline jarn221
Reply #4 on: January 12, 2014, 06:36:48 AM
As an update, the values for all terminals:
Terminal 12 to
1 -0.54
2 -0.55
3 0
4 -0.55
5 -0.54
6 0
7 0
8 0
9 0
10 0
11 0
12 0
14 -0.54
15 0
20 0
21 -0.56
A1 -0.55
A2 0
A3 0.80
A4 0
A5 0
A6 -0.55
A7 0
A8 0.83
A9 0
B1 -0.55
B2 -0.55
B3 0
B4 -0.55
B5 -0.55
B6 0
B7 0
B8 0
When you reference the batteries, what do you refer to?
Also, could this be a transformer problem? Is there any way to test the PT3 transformer to see if it is functioning?
« Last Edit: January 12, 2014, 06:38:31 AM by jarn221 »
Reply #5 on: January 12, 2014, 07:28:37 AM
Jarn,
I was thinking this was a Quickie, not a Crack.  There are no batteries to worry about.
You have no voltage from the high voltage section of the transformer.  Try measuring AC voltage from the transformer terminal 1 to terminal 2.  Assuming you are here, that should be 124V AC plus or minus a couple of volts.  If not the fuse or wiring to the switch is a problem.
If you get that (or 240V AC if you are overseas) then check from transformer terminal 6 to terminal 7.  You should read about 150 V AC.
Notice, both these readings are AC not DC.
Offline jarn221
Reply #6 on: January 12, 2014, 07:57:19 AM
Thanks, we just gave these a shot.
From 1 to 2 we have 123V, so this seems fine.
From 6 to 7 we have 176.6V
and for reference, 9 to 10 we have 176.6V and 4 to 5 we have 5.6V.
Reply #7 on: January 12, 2014, 08:28:23 AM
Your transformer is working properly.
What's the DC voltage between 20 and 21?
Offline jarn221
Reply #8 on: January 12, 2014, 08:41:48 AM
The DC voltage between 20 and 21 is 0.54.
Reply #9 on: January 12, 2014, 08:44:49 AM
Do you have a red and a black wire going to T17 and T18?
Can you post a photo of the power supply in your Crack?
Offline jarn221
Reply #10 on: January 12, 2014, 08:59:49 AM
We have a black wire on 18 but no red or black wires on 17. Only thing on 17 is a UF4007. Attached some images I hope are helpful!
EDIT: Images wouldn't load locally, but uploaded them both here: http://imgur.com/pFSuvjg,uD4IImT
« Last Edit: January 12, 2014, 09:06:36 AM by jarn221 »
Reply #11 on: January 12, 2014, 09:10:44 AM
Check over the manual.  Terminal 17 is supposed to be completely empty.
Offline jarn221
Reply #12 on: January 12, 2014, 09:54:40 AM
Awesome, thank you so much!
After making the changes, these are the voltages we measure.  Are these reasonable? Some seem a bit low.
Terminal 12 to
1 78
2 174
3 0
4 170
5 76
6 0
7 103
8 0
9 101
10 0
11 0
12 0
13 174
14 0
15 196
20 0
21 198
A1 78
A2 0
A3 1.5
A4 0
A5 0
A6 78
A7 0
A8 1.5
A9 0
B1 74
B2 175
B3 104
B4 74
B5 175
B6 101
B7 0
B8 0
Reply #13 on: January 12, 2014, 10:02:11 AM
I think you're ready to give it a listen!
Offline jarn221
Reply #14 on: January 12, 2014, 03:57:38 PM
Thank you so much for your help!  We really really appreciate it.  It sounds great!  We're about to put in the Speedball upgrade.
