What I wish:
Reap · 5269
Offline Reap
on: January 13, 2014, 03:51:05 AM
I just built a pair of Paramounts and love them. I run my entire home theater system thru them via a Yamaha RX-V2095 receiver that has preouts. What I really wish is that the PreBee had connections to hook the flat screen to it, an iPod docking station, an RAII circuit with phono inputs, an AM/FM tuner section, and a wireless remote. I know this is asking way too much. But what are my reasonable options? I would really love to build this preamp, but it also would have to wait another year or two.
Offline Alonzo
Reply #1 on: January 13, 2014, 05:12:55 AM
Depends on your "hacking" skills.  The iPod doc and wireless remote aren't hard to add, layout and power would be a concern, added noise from the attenuator motor...  the RIAA circuit would be the next step up the ladder in modding; off the top of my head, this would have to be in a separate box for sound quality.  The AM/FM, not going to happen, you could just use the app in the iPod for radio.
Brighter minds will chime in, do a search and you'll see the answers on a tuner kit.  The BeePre looks pretty full, the remote motor and dock power could be added vertically with a power brick connection on the back of the base.
I don't think you can DIY a full receiver, but most of the functions can be done.  It would be a compromise...
Alonzo
Reply #2 on: January 13, 2014, 05:53:53 AM
Most of what you listed can be built a la carte.
(How/why would you want to wire the flat screen to it?)
The size, cost, and support limitations all prevent us from offering something this complicated.
Offline Reap
Reply #3 on: January 13, 2014, 06:01:21 AM
My flat screen is hooked up to the Paramounts right now. I would not build something this awesome then let it collect dust. You should have heard the Seahawks game thru them.
Reply #4 on: January 13, 2014, 06:13:50 AM
Well, you can wire the analog output of a TV to the BeePre/Paramounts.
A lot of TV's will also split out the digital audio feed from the HDMI cable, which you can then route to a 5.1 processor, then to your Paramounts.
Offline Reap
Reply #5 on: January 13, 2014, 06:21:21 AM
Yeah, I figure I have at least a year to work this puzzle. And I may never do anything different either. I am very please with the sound. The only problem is that I like a good problem to solve. Electronic design isn't my forte and I know it. But I do pretty well on soldering and following instructions. System design, that's the issue here and I like it.
Am I really the unusual person with a tube amp connected to a TV though? I kind of thought that most would do this. And I cannot imagine why you would not. I've never cared for 5.1 or 7.1 speaker systems. I was born with 2 ears and I only need a speaker for each one. If someone has to do some sound field processing to make me believe something that is not as it sounds, well, I figure they're just trying to compensate for some other short comings. Just give me something simple that works as designed. My ears know artificial when they hear it.
Reply #6 on: January 13, 2014, 08:32:22 AM
Yeah, unfortunately, taking a 5.1 signal and getting it back into a 2 channel format often doesn't work so well.
There are plenty of folks out there using BH amps with their TV's.
« Last Edit: January 13, 2014, 08:53:29 AM by Caucasian Blackplate »
Offline Reap
Reply #7 on: January 13, 2014, 08:44:13 AM
Oh, it's not working poorly at all. I'm using the 2 main channels. I just think it might be able to sound better.
Offline mpeg2
Reply #8 on: January 13, 2014, 09:36:58 AM
Muck around with the configuration menu on your TV - many provide for downmixing the 5.1 to stereo for the analog output (and they do a pretty good job of it)...
   Rich
Offline Reap
Reply #9 on: January 13, 2014, 10:07:51 AM
Already did that. But thanks!  8)
Offline Hank Murrow
Reply #10 on: January 13, 2014, 01:38:24 PM
I am using the OPPO BD 95 player, BH linestage, 2A3 amp, and Orca/BUF Subs for my video watching. Real nice on Public Broadcasting and some BlueRays.
Cheers, Hank
Offline Reap
Reply #11 on: January 15, 2014, 02:32:50 AM
Well, the necessity of the preamp to have an iPod docking station has been eliminated. My PS3 is much more valuable then I realized before. It is now networked with my computer and will play the music from it. Score one for my other online friends for this suggestion.
