Integration problem
Dr. Exotica · 5052
Offline Dr. Exotica
on: January 14, 2014, 06:54:05 AM
I am having a problem with the Integration C4S board in one of the four subcircuits - perhaps someone has some insight.
The tale of woe:
  • Assembled the Seduction, all checked out, sounded quite nice
  • When building the Integration boards, I found out that only two (rather than four) of the 356 ohm resistors were included in the kit. I decided that rather than hassling Eileen for two resistors, I would pick up some at Radio Shack
  • A few days later when headed out to work, I briefly checked the manual and thought I needed to pick up some 120K ohm resistors. Stupid mistake on my part.
  • I built the boards, connected it all up, and of course the voltage readings were way off. ~25-30Vdc rather than 60-90Vdc (this is from memory).
  • After a whopping 5 minutes reviewing what I had done, I realized the resistor mistake.
  • I picked up some resistors (had to run two in series to get close to 356) and soldered everything up.
  • Three of the four sets of LEDs lit up. Three of the four subcircuits read correct voltages (76-77Vdc).
On the problem channel, I read the following:
  • 0A   102
  • 1A   104
  • 0B   85
  • 1B   104
  • MJE350-E     103
  • MJE350-C     103
  • MJE350-B     102
My understanding is that item 2, 4, and 6 should be around 77Vdc in order to match the other three subcircuits on the C4S's.
Any ideas? All looks fine with visual inspection. I hope I haven't fried one of the transistors or LEDs.
Many thanks,
Erik
Surprisingly, lots of old flat earth chrome bumpered Naim gear - Linn LP12/ARO/Linn Troika/Prefix/Hi-Cap/Armageddon, NAT 01, NAPST, CD3-5, Hi-Cap, 32-5 (72ed), Hi-Cap, Headline 2, NAPSC 2, 2 x 135s, Black SNAICs, NAC A5, Fostex 166FE back loaded horns, Standesign Penta,  Audiotech rack, main spur
Reply #1 on: January 14, 2014, 10:19:49 AM
The resistor value is 237 Ohms for the C4S R1.
Your IA/OA are about the same voltage (the IB/OB are in the ballpark).  Can you swap tubes to see if this follows a particular tube?
Offline Dr. Exotica
Reply #2 on: January 14, 2014, 11:38:13 AM
You are correct wrt 237 Ohms for C4S R1. I checked my board (brought it to work today) and I have a 220 Ohm resistor in series with a 15 Ohm resistor for R1. Figured 235 Ohms was close enough.
I'll try swapping tubes tonight.
Reply #3 on: January 14, 2014, 11:39:31 AM
The other common issue is that the center leg of the MJE350 dissipates a lot of heat, and is a little difficult to solder properly sometimes.
Offline Dr. Exotica
Reply #4 on: January 14, 2014, 03:26:28 PM
PB yells bingo!
Exactly right. I tried rotating the problematic C4S (two symmetric circuits) and swapped the tubes. Looks like one of the 6922's is bad - the wonky voltages followed the tube.
Thought I was losing it with assembly - glad (kind of) it was the tube. First bad tube I've ever had.
Thanks for the help.
Erik
