Bottlehead Kits
Crack
Speedball Voltage Check Short?
lickitysplit09
2337
lickitysplit09
Newbie
January 14, 2014, 07:51:58 PM
Hi Bottlehead members,
I recently did my speedball upgrade but had some troubles at the end of my build. I believe I shorted the LED at pin A8 while I was doing my voltage check. Please see below the voltages while I was doing my initial voltage check and afterward to see if you can help identify possible causes. Thanks in advance for the help!
While:
Terminal
1 93.6
2 167
3 0
4 167
5 92
6 0
7 111
8 0
9 110
10 0
11 0
12 0
13 167
14 0
15 187
20 0
21 didn't measure
A1 88.3
A2 0
A3 1.5
A4 0
A5 0
A6 81
A7 0
A8 X
After:
Terminal
1 167
2 172
3 0
4 172
5 92
6 0
7 164
8 0
9 112
10 0
11 0
12 0
13 172
14 0
15 190
20 0
21 210
A1 89.5
A2 0
A3 1.5
A4 0
A5 0
A6 167
A7 0
A8 15.8
A9 0
B1 167
B2 172
B3 165
B4 88
B5 172
B6 111
B7 0
B8 0
Paul Birkeland
Global Moderator
Hero Member
Re: Speedball Voltage Check Short?
Reply #1 on:
January 15, 2014, 10:20:49 AM
Yes, it looks like you damaged an LED.
FWIW, if they are glowing, there is 1.5V across them. We have removed this voltage check entirely from the newest revision of the Crack manual.
lickitysplit09
Newbie
Reply #2 on:
January 15, 2014, 07:25:49 PM
Thanks for the help. Is there a way I can order this through Bottlehead? I am a local in Bellevue.
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
January 16, 2014, 08:42:56 AM
You can e-mail replacementparts(at)bottlehead(dot)com
Bottlehead Kits
Crack
