d cell solution
aragorn723 · 4041
Offline aragorn723
on: January 17, 2014, 02:37:16 PM
Hi everyone,
Just came across an interesting solution for D cell batteries on amazon.  It is a D cell adapter that allows you to put 2 batteries inside to increase capacity!
http://www.amazon.com/ColoYourLife-Colorful-Converter-Microfiber-Packaging/dp/B00CI5BJ7I/ref=sr_1_5?ie=UTF8&qid=1390008748&sr=8-5&keywords=battery+d+adapter
Think it will work well?
Dave
Reply #1 on: January 17, 2014, 06:10:06 PM
A D-cell alkaline battery is "supposed" to be 17,000mAh, a AA of similar quality will be 2,100mAh.  If you put 2 in parallel, that is 4,200mAh (with some assumptions).
So, you would really want 8 AA batteries in parallel to get close to what a D cell will do in terms of lifetime.
Duracell D-cells are about $1.50 each, AA's are $0.40 each.
Offline charger
Reply #2 on: February 09, 2014, 03:22:33 AM
at which voltage Dcell have to be changed ?  at 1 Volt does they are still good enough to feed the Q ?
Oppo 980H - PC - Arcam rDac- Bottlehead Quickie- Abletec ALC040 - Signal cables Atlas Element Integra-speakers cables Tellerium Q black-Martin Logan Motion 15
Offline Natural Sound
Reply #3 on: February 09, 2014, 04:52:10 AM
I run mine down until there is either A. Distortion or B. No sound. The Q will let you know when its time. That's how I do it anyway. I don't think there is a "magic" number for the voltage.
Offline Bonzo
Reply #4 on: February 09, 2014, 05:02:33 AM
Ciao,
I use this adapter.
In my opinion it can be useful if you want to use rchargable batteries, as AA ones are cheaper than D.
Bisogna avere orecchio!
Offline oxide2k
Reply #5 on: March 05, 2014, 08:59:43 AM
Reply #6 on: March 05, 2014, 10:23:23 AM
The average alkaline D cell is rated for 12,000 mAH.  A rechargeable AA will be 600-3000mAH.
The link that you posted is for an adapter that will put one AA cell into a piece of plastic that fits where a D cell would go.
« Last Edit: March 05, 2014, 12:27:44 PM by Caucasian Blackplate »
Reply #7 on: March 05, 2014, 11:31:14 AM
A good NiMH rechargeable D-cell is rated for 10,000 mAh. They're just expensive ($15-20 each) and harder to find.
