Voltage Check Question...
skes16 · 2082
Offline skes16
on: January 18, 2014, 03:40:52 PM
Hello all, and thanks in advance for your help!
Today I added the speedball upgrade to my crack, and when it came to my voltage check, everything was fine except for terminals 19 and 20. 19 is supposed to have a value of 0, but shows up as 85. 20 is supposed to have a value of 206, but shows up as zero.
After checking absolutely everything and finding no problems, I did the final check and everything was okay.
After being plugged into a source and listening for a little while, everything seems to be working great but I am unsure if that is a good enough indication that nothing went wrong.
Should I continue to worry about these voltages, or should I be okay?
Thanks!!
Reply #1 on: January 18, 2014, 03:46:30 PM
There was a transcription error in the manual that led to some values being shifted.
If terminals 1, 2, 4, 5, 7, and 9 have correct voltages, you're all set!
Offline skes16
Reply #2 on: January 18, 2014, 03:57:17 PM
Awesome, that's a huge relief thanks!
