Only 45 volts on terminal 2 (now fixed)
Aussie Blue · 3924
Offline Aussie Blue
on: January 20, 2014, 07:04:15 PM
Supposed to be 70-90v. Everything else measures fine. Switching tubes doesn't change the reading. Is this indicative of a problem?
The unit plays/sounds great. Should I just relax and enjoy, or is there something to fix?
K.
« Last Edit: January 21, 2014, 06:37:18 PM by Aussie Blue »
Reply #1 on: January 20, 2014, 07:09:12 PM
Yes, it certainly is. 2 and 7 should both change a little bit when you switch tubes.
You have the red wire curling in to terminal 4?  Do you have 0V DC at terminal 5?
Offline Aussie Blue
Reply #2 on: January 21, 2014, 09:51:22 AM
Yes, red wire from PS #57 is connected at 4, with 144.5v.
There's a slight (1.5v) reading on 5.
Thoughts?
Many Thanks,
Kevin
Reply #3 on: January 21, 2014, 11:43:56 AM
Well, that's not so great!
Follow that black wire leaving terminal 5, and solder every solder joint along the way till it hits the solder lug at the chassis.
Also - this wire is supposed to go to pin 9 on the 9 pin socket, your issue could be 100% explained by this wire accidentally going to pin 8 on that socket instead.
Offline Aussie Blue
Reply #4 on: January 21, 2014, 06:34:06 PM
Yeah, that's it arright... Upon review, I noticed something was fishy when compared to the finished photo in the amplifier circuit.
With all the ground wiring obscuring A9, I just kind of transposed pins with the black wire, mistaking A8 for A9 (Doh!).
Re-connected and cleared low voltages right up.  Now hummin' along.
Now to get busy spinning some vinyl. ;D
Thanks All for the great support!!!
K.
« Last Edit: January 21, 2014, 06:39:14 PM by Aussie Blue »
