Crack + Speedball upgrade help
sleyk · 5216
Offline sleyk
on: January 23, 2014, 03:31:42 PM
I am trying to build a speedball upgrade on my crack kit and run into some issues.
When i initially built it, there was smoke coming out of the 270W resistor at terminal 15.  I shut it off and resoldered the loose capacitor to remedy the issue.  I also changed my tube to a tungsol 5998 from the old 6080 stock tube.
I ran a voltage check and all of the voltages are way off
1         1.71
2          4
3          0
4          0
5         2.06
6-13      0
14        .5
15         0
A1     -.6
A2     .3
A3    -.05
A4     0
A5     .03
A6     0
A7     0
A8
Help would be greatly appreciated
Reply #1 on: January 23, 2014, 04:00:23 PM
Check your fuse.
Offline sleyk
Reply #2 on: January 24, 2014, 11:31:16 AM
I found a loose wire from B2 ---> 2 and resoldered it.
The voltages are still off:
Terminal     Voltage    Expected
1                -1.05
2                .58
3                0
4               .58
5               -1.14
6               0
7               0
8               0
9               0
10             0
11             0
12             0
13             .57
14             .57
18            92
19            94
20              0
21             246
B1           -1.04
B2         0
B3          0
B4           -1.16
B5         .56
B6-8      0
A1-9     0
The 5998 tube lights up but the bottom tube lights up slightly.  None of the LEDs respond.  I checked the fuse and gone over all the wiring to no avail.
Offline sleyk
Reply #3 on: January 24, 2014, 11:53:08 AM
Also, I noticed that the 270ohm which was smoking cracked.  I used my multimeter to check the resistance and it reads at 281 ohms.  Could the cracked resistor be the issue?
Offline sleyk
Reply #4 on: January 24, 2014, 12:05:02 PM
I found that the 270ohm 1w resistor from 21 to 14 reads -.60 on the multimeter.  Does that  need replacing?
Reply #5 on: January 24, 2014, 12:25:04 PM
A cracked resistor means it got so hot that it gave up.  This means that there is a short downstream from that resistor.
I would replace them both (they are 5W), then get back to us.
Another user reported a similar issue, as he had left off the insulating shoulder washers that to between the mounting screw and the TIP50 on the bigger Speedball board.
Offline sleyk
Reply #6 on: January 25, 2014, 12:31:51 PM
I had trouble finding a 5w 270 ohm resistor.   I talked to a guy at the front and he said a 10w 270 ohm works just as fine if not better since it runs cooler.   Is it okay if I use a10w resistor instead?
Reply #7 on: January 25, 2014, 02:17:11 PM
Sure, a 10W will work well.
Offline sleyk
Reply #8 on: January 26, 2014, 02:58:56 PM
I also can't seem to find any nylon shoulder washers.  What is the name of the washer: Nylon #6 Shoulder wash (x4)?
Reply #9 on: January 26, 2014, 03:25:11 PM
Now I'm really confused.  You have built Crack and are checking voltages, how do the nylon washers come into play?
Offline sleyk
Reply #10 on: January 26, 2014, 04:03:09 PM
Sorry for being so brief.   As stated earlier in the thread,  another user had the same issue with voltages and didnt place the shoulder washers in.   I can't seem to find the washers so it may be causing a short
Reply #11 on: January 26, 2014, 05:16:26 PM
A shorted power transformer will not cook a component downstream from the power transformer (your 270 Ohm resistor).
Offline sleyk
Reply #12 on: January 26, 2014, 06:06:12 PM
I am missing the nylon shoulder washers for the circuit board.   I was hoping I can get the size and name of the type of washers.   I apologize for miscommunicating my concerns.   Thank you!
Reply #13 on: January 26, 2014, 06:19:55 PM
Are you referring to the nylon standoffs used to mount the boards?  Are you missing all 4 of them?
Offline sleyk
Reply #14 on: January 26, 2014, 08:14:39 PM
Thank you!  I left off the insulating shoulder (i thought they were made of nylon and 4 of them.  I also replaced my 5w 270ohm resistors with 10w 270 ohm resistors.  I did a voltage check and everything is within 15% of the predicted voltage readings!  I appreciate the advice and the patience you have provided me!
