Reduce Gain in PJCCS'd Quickie?
MarkInWisconsin · 17178
Offline MarkInWisconsin
on: March 21, 2010, 08:26:48 AM
I just PJCCS'd my Quickie.  It sounds fantastic, but now I have too much gain when running through my Paramour's and Klipsch Heresy's.
Can someone explain to me how to reduce the gain out of the Quickie?
Thanks in advance!
MarkInWisconsin
Offline machinehead
Reply #1 on: March 21, 2010, 10:20:22 AM
You could try a potentiometer with a higher resistance like this:
http://www.mouser.com/ProductDetail/ALPS/RK27112A-S20-C0-A254/?qs=hm0oVamVljsxpd34aFZJ/A%3d%3d
or add an in line resistor to the output of the potentiometer.  Try different values until the lowest volume setting is suitable.  You may want to start with something like 10K ohms.
Once you find the right value, replace with a good quality resistor like a Mills.  You will also need the correct wattage, not sure what that will be.
Reply #2 on: March 21, 2010, 06:48:20 PM
Remove the jumpers that go between the selector switch and the volume pot, then replace them with 100k resistors.
-Paul
