Made a big mistake with the main power supply :'(
fissure · 7113
Offline fissure
on: January 29, 2014, 11:46:58 AM
So i received my Crack and Speedball yesterday and finished building it today. Checked resistances and then plugged it in and checked all the voltages. But they were MUCH higher than they were supposed to be. Only the large tube lit up and the small remained dark. Rechecked all wiring 10 times but could not find any bad leads or connections.
Now i went into the webpage here to look through some posts and looked at the order page also for some reason and thought about the tick box for a 220V transformer... well i just realized i have no such transformer (did not get any power cables at all, but that might be normal?). I was convinced i ticked that box when i ordered and thought to myself that there was some component switched to allow the higher voltage so i never reflected over not having a transformer.
Looking through my the order that was emailed after my purchase i see no such thing as a 220v transformer so i most likely missed it or forgot it (though i now seeing it when ordering)
Now my question is how do i get such a transformer and did i destroy the entire build now when connecting the 220v mains to it ? :'(
Offline fissure
Reply #1 on: January 29, 2014, 11:53:02 AM
Nevermind, went through the checklist with the package and saw that the transformer is the one in the box and it is checked and have 240V hand written next to it. So it is not an external transformer i assume?
So question now is why my small tube wont light up :/
Is there anyway to test it?
Reply #2 on: January 29, 2014, 12:12:19 PM
What transformer are you supposed to have (i.e. what country do you live in?) What is your real name?
Reply #3 on: January 29, 2014, 12:18:16 PM
Also, what does the sticker say on the transformer itself?
Offline fissure
Reply #4 on: January 29, 2014, 12:25:01 PM
Hi there, on the transformer it says 240V Bottlehead PT-3.
I live in Sweden and here we have 220V on the mains. The 6 and 9 on the transformer where it says 150V have 156V out from them so that seems to be okey. Problem is that on 19 i have 156V but then on 21 I have 450V ? Must have wired something wrong but cant find it...
« Last Edit: January 29, 2014, 12:27:24 PM by fissure »
Reply #5 on: January 29, 2014, 12:31:22 PM
So 156V AC comes out of 6/9?  What is the AC voltage at terminals 4/5?
19 isn't a terminal with a meaningful voltage on it, so that's worth ignoring.
Where are you touching your black meter probe to perform these measurements?  Can you measure the DC voltage between terminals 20 and 21?
Offline fissure
Reply #6 on: January 29, 2014, 12:45:14 PM
Sorry i have 159V on 6/9 (on the transformer).
I am measuring with the black probe on terminal 12 fixed between the terminal and the cap leg.
When you say terminal 4/5 are you meaning on the transformer or the front terminal.
4(Transformer)-0V
5(Transformer)-5.2V
4(Front terminal)-343V
5(Front terminal)-303V
20/21-454V
I suspect something is very wrong? :P
Went through the manual yet again and just cant find any wiring error.
Might also mentioned i chose to wire the 4 on the transformer to terminal 14U as it said in the revision in the manual.
Reply #7 on: January 29, 2014, 12:46:30 PM
Could you post a pic of the wiring around the transformer?
I can think of a way or two that this might happen, but it's tough to describe it in words.
In any event, we'll get you sorted out.
Offline fissure
Reply #8 on: January 29, 2014, 01:01:44 PM
Here are some pics on the transformer, sorry about the quality. I placed the AC and line in and out on the backside if you wonder why there are wires going there.
Offline fissure
Reply #9 on: January 29, 2014, 01:07:19 PM
Here is a couple of more pics.
Offline fissure
Reply #10 on: January 29, 2014, 02:13:12 PM
Meh i have been measuring AC and not DC. Stupid me.
Still something are not right will post the measurements here.
1 75-90 - 136
2 170 - 151
3 0 -
4 170 - 150
5 75-90 - 135
6 0 -
7 100 - 136
8 0 - 0
9 100 - 136
10 0 -
11 0 -
12 0 -
13 170 - 152
14 0 -
15 185 - 178
20 0 -
21 206 - 203
A1 90 - 138
A2 0 - 0
A4 0 -
A5 0 -
A6 90 - 138
A7 0 -
A9 0 -
B1 90 - 139
B2 170 - 152
B3 100 - 137
B4 90 - 137
B5 170 - 152
B6 100 - 137
B7 0 -
B8 0 -
20/21 - 202VDC
Offline fissure
Reply #11 on: January 29, 2014, 02:47:45 PM
Starting to wonder if the 12AU7 tube is broken. The 6080 lights up fine but the AU7 tube remains dark and cold and the leds are not lighting up. Tested them both with the black measure point in the center of the socket and the red on each of the pins and then both leds light up. :/
Reply #12 on: January 29, 2014, 04:22:56 PM
Set your meter back to AC. Measure the voltage from pin A4 to pin A9. It should be about 6.3VAC. Also measure from A5 to A9. A4 and A5 are connected together so you should get the same 6.3VAC reading. If you don't see those voltages check the connections of the wires connected to those pins and trace them back to check the connection at the other ends too.
Reply #13 on: January 29, 2014, 06:52:58 PM
There is a black wire that leaves terminal 12 and heads up to the headphone jack - your amp doesn't have this wire.
Offline fissure
Reply #14 on: January 30, 2014, 12:42:21 AM
Hi guys!
Doc.B
I just measured the voltages between A4/5 and A9 and i get 5.2V also measured all the way back to the transformer and i have 5.2V between B7 and B8 and 5.2V between transformer pins 4 and 5.
Caucasian Blackplate
I have two wires going out from terminal 12 one connected to U14 and one to the TSR ground pin.
I have a neutrik TSR jack mounted in the wood backside.
Edit: Made some VDC measurements on the power socket and had a bad solder in the socket. Was getting 220VDC instead of 230VDC(Swedish standard) so the 6,3 pin on the transformer now gives 5,6VDC instead of 5,2. Still to low though. Noticed the transformer says 240 volts and since we only have 230 here in Sweden that might explain the lower output on the 6,3VDC tab?
Still not getting the 12AU7 tube to light up though and the voltages on the A socket is still to high. Any ideas?
Cant do any more testing now since i blow the fuse due to some bad measuring on the power socket so will have to go get some new ones.
« Last Edit: January 30, 2014, 02:34:53 AM by fissure »
