Bottlehead Kits
Crack
Smoking + no sound output
swuuggs
2236
swuuggs
Newbie
February 07, 2014, 11:44:26 AM
Just got done building my crack, and don't have any sound being outputted from the amp.
Also, the unit gets incredibly hot, and smokes slightly.
It passed all the ohm and voltage tests, as far as I know.
Any ideas what the problem could be?
Grainger49
Hero Member
Re: Smoking + no sound output
Reply #1 on:
February 07, 2014, 11:59:24 AM
Ok, Smoking is bad!
Post your resistance readings that are +/- 15% out of spec. I'm willing to bet that there are some that are wrong.
If not, did you install the Speedball in the initial build?
swuuggs
Newbie
Reply #2 on:
February 07, 2014, 12:33:47 PM
No speedball.
Here are my ohm readings. I understand they are quite abnormal.
I'm new to this, so it's probably an issue of a grossly mis-wired unit.
Terminal: Ohm reading (k):
1 - 0
2 - 0
3 - 0
4 - 0
5 - 0
6 - 2.465
7 - 0
8 - 0
9 - 0
10 - 2.486
12 - 0
13 - 0
14 - 0
20 - 0
22 - 0
b3 - 0
b6 - 0
Warning: this is the ugliest wiring job you have ever seen. Also, all of the wiring ports are fucked because I painted the wrong side of the metal, so all the components are installed on the wrong side.
http://imgur.com/a/trogl
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
February 07, 2014, 12:40:10 PM
I would buy a new kit without the wood base and start over.
There are so many safety issues with what you've done here that I would implore you to not plug it in.
All your resistances are 0, so it failed those tests.
I can tell that all your voltages will be incredibly close to 0 as well.
I'm going to lock this thread, as we cannot offer support on something that isn't a Crack (it deviates too far from the manual).
Last Edit: February 07, 2014, 12:42:45 PM by Caucasian Blackplate
Bottlehead Kits
Crack
