Power Consumption?
poohsan · 19657
Offline poohsan
on: March 25, 2010, 02:37:44 AM
How many watts would you suppose (or even better, know!) that a 110V Seduction uses?
I've moved to a 230V country and have step-down transformers and I'd prefer to use the smallest one possible (likely a 3000W unit) instead of the 750W unit that it's currently plugged into.
thanks.
Reply #1 on: March 25, 2010, 03:06:50 AM
The Foreplay III and a Seduction can both be powered by a 300VA transformer.  The Seduction alone was quoted by Paul Joppa as 15-20VA back in 2005.  A Volt-amp is like a watt but more complex.  Most transformers are rated in VA.
