What can a knucklehead do with a Tektronix 2215?
Downhome Upstate · 3831
Offline Downhome Upstate
on: February 08, 2014, 01:26:05 PM
$105; seems to work ok. Can those of us without experience (or memory of past experience) make good use of these babies on our own, fiddling around with dead and dying tube gear?
"Too soon old;
   Too late schmart"
    The late Mr. Fox, Fox's Deli, Rochester, NY
Mike P.
Offline John Swenson
Reply #1 on: February 10, 2014, 02:19:07 PM
The 2215 is actually a very good scope to use with tube gear. It has an input range of 400V which is extremely high for solid state scopes.
Does it have any probes with it? If not you will need to get some. For use with tube gear you need to get probes that can handle the voltage. The "standard" 10X probe can usually handle 600V which  is fine for a lot of tube work, at that max of 600V it is delivering 60V to the scope. You have PLENTY of margin there with a 400V input range! With that 400V range you won't fry the scope if you run direct without a 10X probe.
You can also get 1200V 100X probes, these are great for tube work and not very expensive. If you know you are going to be doing a lot of audio tube work with the scope  these 1200V 100X probes would  probably be a good investment. No matter what you did you probably would not fry anything.
There are also high voltage differential probes, these are great but not cheap, several times the cost of the scope. But for some things they are one of the few ways to see what is happening. (for example put one connection on the cathode of a tube and the other on the plate to see what is happening across the TUBE, not between ground and the plate). For example I  have an amp where the cathode of a power pentode is bouncing around all over the place and I want to see what is between the cathode and  the screen, the  differential probe is great for this. They are also completely isolated from the scope, thus there is no risk  of shorting something out to the scope ground. See below on this aspect.
Two words of warning when working on  tube circuits, the ground wire on the probe is connected to the mains ground pin, be EXTREMELY careful where you connect this on tube gear. If where you connect it is NOT connected to mains ground (say a couple hundred volts) you can easily fry your scope probe, your scope, the tube  circuit you are working on and maybe even you. (this is one reason I REALLY like a high voltage differential probe)
Number two, hook up the probe to what you want to test with the gear OFF, make sure the probe is going to stay where you put it, THEN turn  the power  on the gear. RESIST the temptation to hand hold a probe and go poking  in around  a live tube circuit. If you don't heed this you WILL destroy something, somewhere along the line.
I don't want to scare you away from using the scope, just be mindful of the high voltages, get probes that can handle what you are working on and think carefully about what you are doing.
If  you are going  to be working on  gear for which you don't have a schematic or are not familiar with the circuit, one of those high voltage differential probes  might be a really good investment. That issue of connecting the ground clip to something that isn't at ground potential is a serious issue when working on unknown  gear, the differential probe completely gets rid of that issue.
John Swenson
DAC designer
Moded Squeezebox->DIY DAC
Reply #2 on: February 10, 2014, 03:20:21 PM
Wow, i never knew that.  I have the 2225 which is rated for 400v p2p so i never connected to the HV side of the amp as its ~420v.  If only i had known that about the 10x probes as i have two of them.
Thanks John!
@Downhome Upstate, i had no idea how to use mine when i bought it, i was just curious to learn.  ^ and still learning.  Couldn't live without it now, its as useful as a multimeter and soldering iron.
Reply #3 on: February 10, 2014, 03:40:16 PM
Thank you kindly, John. Think I'll grab one (and a pair of those 100X probes - the more expensive ones just aren't in the tool budget). Looking forward to seeing your BH DAC project come to fruition.
"Too soon old;
   Too late schmart"
Mike P.
Offline galyons
  • Geary Lyons
Reply #4 on: February 10, 2014, 03:59:09 PM
Wow! What good timing! I am looking at a Techtronics 2235.  Still waiting to see if the seller can find the probes! Now I can at least ask the type!  I am a scope newbie trying to improve my tube audio skills.  From what I have read, this scope would also be good for tube audio?
Cheers,
Geary
Offline Mike B
Reply #5 on: February 10, 2014, 04:41:38 PM
Just buy it.
That stuff was multi-thousand dollars when new.
If it works, just buy it.
Offline galyons
  • Geary Lyons
Reply #6 on: February 13, 2014, 09:52:41 AM
Just buy it.
Ok, but only because you insisted!!  So here is my "new" Tek 2235!  $75 and a bit of a drive, but everything seems to work!  (At least at my twiddling level so far!)  Had to break down the probe and clean the connections.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FYDFjlQq.jpg&hash=16707b06597f2d5981ea56659e640eec25cf32d8)
And I dug out my old Heathkit Signal Generator!! Fired up and ready! (Need to replace the multi cap, it is  a bit flakey! Then I'll clean all of the switches & connections )  Should I be considering a more modern function generator?
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FyAldTrW.jpg&hash=6af30ecfcff2b6b0bdfe63f9e0b4aeb4aa515617)
Now i just need to learn how to use it!!  YouTube and the manual!  Any suggestion for a good audio measurement related tutorial?
Cheers,
Geary
Reply #7 on: February 13, 2014, 10:01:45 AM
You got a bargain there for $75, congrats.
