Another DC coupling question
vetmed · 3301
Offline vetmed
on: February 09, 2014, 06:28:24 AM
Having changed my power supply to use solid state rectification I now see a blue flash inside the 71A plate on start-up, and although so far it continues to work I am sure this is not good in the long term ::) I think what is happening is that the driver tube's plate voltage rises beyond its normal operating value at startup because its cathodes are cold. So the plate voltage of the driver tube rises to ~ 300 volts before falling back to its normal value of 150 volts. Evidently the output tube's grid doesn't seem to like this :o
   So I am wondering if installing a high voltage diode from the output tube's grid to the top  of the cathode resistor would work, striped end (cathode) to the tubes cathode? I think what should happen is that the excess plate voltage of the driver will bypass the grid until the tubes are warmed up. Then, because the output tube's cathode voltage is higher than the grid voltage, the diode would be reverse biased and no longer conduct. Seems simple and should work, but keen to see what other more knowledgeable people think. Thanks
Robert Lees
Offline johnsonad
Reply #1 on: February 09, 2014, 07:12:07 AM
Why not install a couple of switches. Shunt the B+ to ground until the filaments are warm and the B+ has stabilized, then flip the switches on.  You could be fancy and use relays but switches work nicely.
Reply #2 on: February 09, 2014, 07:14:52 AM
That will blow the fuse immediately.
Reply #3 on: February 09, 2014, 01:05:56 PM
The diode should work. I have heard people say that it damages the sound very slightly, but then you hear a lot of nonsense on the internet ...  :^)  Easy enough to try, and should be perfectly safe.
Offline vetmed
Reply #4 on: February 09, 2014, 04:51:33 PM
Thanks Paul. I have tried it and I am happy to report no more blue flashes or pops at turn on 8)  Nor does it seem to have any effect on sound quality, not that I expected that it would, being very sceptical about magic wires and other audio fairy tales ;D
Robert Lees
