Help, voltage problem!
smallmany · 9720
Offline smallmany
on: February 09, 2014, 07:34:09 PM
Resistance
1 0
2 0
4 0
5 0
VDC
1 0
2 0
4 0
5 0
7 65
9 62
13 198
15 210
A1 0.1
A3 0.6
A6 0.1
B1 0.1
B3 64.3
B4 0.1
B6 61.4
Off my multimeter, the 9pin socket should have zero voltage but both my tubes filaments glow. The sound comes out but is really quiet. There is a loud constant hum at any volume.  Both the LEDs are not glowing.
Any ideas? Help
tl;dr No voltage at 9 pin socket. Low voltage at 8 pin socket. But there is sound just not very audible/distorted + constant hum
« Last Edit: February 09, 2014, 08:44:17 PM by smallmany »
Reply #1 on: February 10, 2014, 07:42:48 AM
Having 0 Ohms at 1-5 means don't turn the amplifier on....
Since terminals at 1-5 are directly wired to other terminals, you should have other resistances that are off.
Can you post a full list of these?
Is there any way you can upload pics of your build?
Offline smallmany
Reply #2 on: February 10, 2014, 09:03:06 AM
Welp, I was missing the wire from B2 to 2L.
So I solved the resistance problem but the LED connected to A8 is not lighting up.
I can't remember all but terminal 1 had voltage of around 150v
Offline smallmany
Reply #3 on: February 10, 2014, 11:00:18 AM
is the LED important or is it just a indictation that voltage is running through
Reply #4 on: February 10, 2014, 11:02:11 AM
Again, please post your resistances and do not turn the amp on...
Offline smallmany
Reply #5 on: February 11, 2014, 07:08:51 PM
Is mis-wiring the culprit for my blown LED at A8? If not, what may be the reason? The other LED was functioning
Reply #6 on: February 12, 2014, 03:33:21 AM
How is the LED blown?  Did you hear it snap, did the leads break off, etc?
Reply #7 on: February 12, 2014, 06:27:21 AM
smallmany,
Paul, Caucasian Blackplate, knows this amp as well as anyone alive.  You should be answering his questions rather than asking new questions.  Paul can walk you through fixing this.
« Last Edit: February 22, 2014, 09:55:56 AM by Grainger49 »
Offline smallmany
Reply #8 on: February 12, 2014, 07:51:48 AM
The LED at A8 would not light up. Thinking that it was a cold joint, I reheated the solder, and the lead melted out of the LED.
Reply #9 on: February 12, 2014, 08:04:25 AM
You can e-mail [email protected] and we can send you some additional LED's.
I would encourage you, however, to post all your resistances before turning this amp on again.
If the resistance check is good, then move on to powering up the amp.
For an issue like an LED not lighting, that is certainly what we are here for.  More often than not, this actually has nothing to do with the LED itself, but manifests from elsewhere in the circuit.
Offline smallmany
Reply #10 on: February 12, 2014, 08:57:57 AM
Once the replacement arrives, I'll be sure to give you an update of the readings
Offline smallmany
Reply #11 on: February 24, 2014, 02:17:35 PM
After soldering the new LED, everything checked out almost perfect. The center seems a bit off when i listen to it, i feel like the center is a bit off to the right. Hoping it is just the tubes burning in.
Offline smallmany
Reply #12 on: February 24, 2014, 02:51:16 PM
Also, the tube next to the transformer gets so hot I could cook my eggs on it.
Reply #13 on: February 24, 2014, 03:01:12 PM
That's good, it is working exactly the way it is supposed to.
Offline smallmany
Reply #14 on: February 24, 2014, 04:16:07 PM
I noticed that when i increase the volume, the right side is louder than the left , but is fine at low-medium volume.
