Need assistance addressing hiss
bjorgens · 16551
Reply #30 on: March 06, 2014, 12:20:27 AM
Bryan, PM Sent.
« Last Edit: March 31, 2014, 03:22:28 AM by Grainger49 »
Offline bjorgens
Reply #31 on: March 07, 2014, 09:35:28 PM
PJ,PB, Doc
Replaced the one electrolytic on PS board.  On closer inspection, top was bulging slightly.  Added 10000uF 6.3V caps across -reg and Kreg, and hiss is gone... I mean gone.
Retuned for hum, and system is very quiet
Haven't had much time to actually listen, but MUCH better in terms of noise floor.
Thanks again for all your help
Cheers
Bryan
Bryan Jorgensen
VPI Traveler (Ortofon 2M Bronze)
Coffman Labs G1A preamp/phono/ headphone amp
Paramount 300B monoblocks
First Watt F4 clone
Blumenstein Orca Deluxe speakers and subwoofer
Cardas cabled Sennheiser 600s
Offline johnsonad
Reply #32 on: March 08, 2014, 02:31:47 AM
Bryan, did you use a bipolar or standard 10,000 uF cap? If standard, did the neg side go to the - neg point?
I too would love to eliminate that hiss and this seems like an easy thing to try. For the team, does this mod have a potential to adversely effect the sound?
Also, did Grainger PM you about the hum pot?
Offline bjorgens
Reply #33 on: March 08, 2014, 05:20:12 AM
Howdy
Neg lead went to -reg.  mounting the cap is a tad ticky, as the through holes are too small to accept more than one lead.  I simply bent and soldered the cap leads across the top if the pads... May choose to change the mounting later if I feel ambitious.
So far so good re: sound.  No deleterious effects I can hear... Only good ones.
Re: the hum pot, did not get a part number from Grainger... The 10ohm 10 turn pot I could find was rather expensive (~$50), so I might stick with what I have for now... :)
Bryan
Bryan Jorgensen
First Watt F4 clone
Offline johnsonad
Reply #34 on: March 08, 2014, 05:25:51 AM
Thanks Bryan.  Yes the pots are pricey not to mention large but you pay for precision.
Reply #35 on: March 08, 2014, 07:40:40 AM
... For the team, does this mod have a potential to adversely effect the sound?
[This was the 10000uF cap from kreg to -reg] Yes it does. Let me clarify: many people (including the Bottlehead team) find that a normal cathode bypass capacitor slightly degrades the sound relative to no capacitor. Presumably this has to do with the signal current that flows through the capacitor. In the case of bypassing the 431, the regulator chip has a very low AC impedance (unlike the normal situation where a resistor is bypassed) so the signal current through the capacitor is reduced. So when I agree it has the potential, I mean I don't know whether there is a residual loss or not. At this level of resolution, calculations of current are IMHO not going to predict the subjective effect; only careful listening can do this. Of course it will be confounded with the reduced noise - but at least that's the realistic choice - does it sound better with the cap or without? Results are likely to be different with different speakers as well.
Offline johnsonad
Reply #36 on: March 08, 2014, 07:43:22 AM
Thank you Paul. It's a cheap experiment :)
Offline bjorgens
Reply #37 on: March 11, 2014, 07:22:50 AM
Paul(s)
Ignorant question #74
would a relatively lower capacitance (film) cap do anything with less potential for adverse effect?  I.e. I'm not smart enough to understand why a 10,000uF cap is needed in this particular case.
Even if so, I don't intend to change anything any time soon... I have so many new parts in my system right now, it just needs time to settle down so I can establish a "new normal"
bryan
Bryan Jorgensen
First Watt F4 clone
Reply #38 on: March 11, 2014, 03:29:01 PM
The dynamic impedance of a 431 set for 2.5 volts is about a half ohm. The capacitor has to have a lower impedance if it is to reduce the chip-generated noise. 10000uF is 0.5 ohms at 32Hz, so it will be effective above 32Hz.
Offline bjorgens
Reply #39 on: March 11, 2014, 03:34:02 PM
Thanks Paul... Much appreciated explanation
B
Bryan Jorgensen
First Watt F4 clone
