Need assistance addressing hiss
bjorgens · 16564
Offline bjorgens
on: March 02, 2014, 06:21:19 AM
Could use some assistance to remedy hiss/ white noise on my paramounts
This is not hum, it is white noise that is present regardless of volume level.  Likewise, it is present even with source/ pre amp disconnected and amp inputs shorted with shorting plugs.
Amp is setup with relatively new EML 300Bs and some NOS WE396A tubes. Coupling caps are Vcap, parafeed caps are mundorf Silver in oil.  Noise was present before these components were installed.
Interestingly enough, the hiss is worse in left channel.  There is also an inrush sound when amp is first powered on.
Plate voltage is right at 175VDC on both, and hum is at 2.0mV on both
Any recommendations on where to first start looking?
Bryan
Bryan Jorgensen
VPI Traveler (Ortofon 2M Bronze)
Coffman Labs G1A preamp/phono/ headphone amp
Paramount 300B monoblocks
First Watt F4 clone
Blumenstein Orca Deluxe speakers and subwoofer
Cardas cabled Sennheiser 600s
Offline ffivaz
Reply #1 on: March 02, 2014, 07:32:13 AM
Hi Bryan,
Hiss is often tube related and is not easy to get rid of. Try swapping the tubes to see if the hiss level is linked to your tubes. And try using them for 50 hours to see if it goes away. I had that with my stereomour 12AT7.
I have to say that hiss never completely disappeared from my system and that it is quite common to audio gear. I have a Naim solid state amp with higher hiss level than my stereomour.
Maybe someone at bottlehead has a circuit change that could help you with definitively removing hiss.
Fabien
« Last Edit: March 02, 2014, 07:34:06 AM by ffivaz »
Fabien Fivaz
Offline bjorgens
Reply #2 on: March 02, 2014, 07:53:37 AM
Just flipped over my left channel amp again, and noticed that there appears to be oil leaking from one of the 270uF electrolytics on the power supply board.  .. Not a ton, but presumably any is too much.  Not the case on the right channel amp
Aside from me needing to address this for obvious reasons, could this be source of the inrush and louder hiss on this channel?
Doc B
Am I better off replacing the PS board entirely?
B
Bryan Jorgensen
First Watt F4 clone
Offline johnsonad
Reply #3 on: March 02, 2014, 09:29:23 AM
Those caps need replaced if they are bulging or leaking though they should be electrolytic caps and don't have fluid in them.
The constant white noise could be tubes but if you have high sensitivity speakers, you are hearing the regulator on the driver board.  It's normal for this circuit.
« Last Edit: March 02, 2014, 01:36:41 PM by johnsonad »
Reply #4 on: March 02, 2014, 01:04:36 PM
This is likely worth posting a photo of.
"Oil" could just be some solder flux.  The power supply capacitors in the Paramounts will last a very, very long time.
Offline bjorgens
Reply #5 on: March 02, 2014, 01:39:02 PM
This is a bit of a story...
Re: the oil...It was a lot more than I would have ascribed to solder flux... More on that below
Incidentally, this is the same amp that I sent in to have you guys help me get working after initially attempting to build with what we subsequently learned was a mislabeled transformer.
You fixed it, and I put it happily into use.  The inrush noise/ constant hiss was there at that time on that channel only, but I just figured it was what it was.  I should note that I did not check plate voltage after getting the unit back from you... Again... More on that in a sec.
About a month ago, I read that when changing tubes to reset plate voltage to 175VDC.  Since I had changed the 300Bs some time earlier, I checked the voltage and discovered it was at 215VDC  on the left channel (!)  The other amp was at ~179 IIRC... ie big difference between the two, and for all i know, it could have been that way the entire time.  That was reset to 175, and this was when I also first noticed the oil.  At that time, I thought my coupling cap (a Duelund cast PIO) had failed, so I decided to change that to the Vcap now installed.  I now realize that it was oil from the electrolytic leaking down onto and saturating the coupling cap. At same time I also decided to change out the parafeed caps, and swapped to the EML 300Bs and WE396As.  Plate voltage was reset to 175VDC on the dot.
So... What to do?  A picture won't show much at much at this point unfortunately, as I wiped said oil away already.
Could there have been more initial damage elsewhere than we thought from the mislabeled transformer?
Was my failure to check and set plate voltage after getting the amp back from you a potential culprit?
Or is it just a bad cap?
Thanks as always !
Bryan
Bryan Jorgensen
First Watt F4 clone
Reply #6 on: March 02, 2014, 03:57:54 PM
Hello Bryan,
None of this sounds like anything that would damage the amplifier.  The mislabeled transformer would result in lower B+ voltages - so no harm to the caps.
IIRC - I put a new power supply board in there anyway (I think).
The plate voltage of the driver tube should be 175 +/- 20% (tighter for the 2A3).  If you had 300V on the plate of your driver tube, then we'd be rocketing into that as a problem.
Can you swap tubes to see if this might follow one of the tubes?
BTW - the startup noises are normal to the circuit.
2.0mV of hum is quite high from a Paramount, are you by chance on the 16 Ohm setting?
Offline bjorgens
Reply #7 on: March 02, 2014, 04:05:23 PM
Thanks Paul!
Does not follow the tube on previous tries, but I will double check on that and the impedance setting and advise ASAP
Cheers
Bryan
Bryan Jorgensen
First Watt F4 clone
Offline bjorgens
Reply #8 on: March 04, 2014, 06:55:47 AM
Paul.
confirmed that noise does not follow the tubes, and OT is wired properly for 8ohms.
b
Bryan Jorgensen
First Watt F4 clone
Reply #9 on: March 04, 2014, 08:22:46 AM
Hello Bryan,
OK, this is helpful information.
In the amplifier, there is a 249K resistor on the terminal strip by the 300B tube.  Can you temporarily solder a piece of wire across this resistor, then listen for hiss again?
This will remove the contribution of the driver stage and isolate the source of the hiss to one half or the other of the amplifier.
Reply #10 on: March 04, 2014, 10:15:49 AM
Brian,
IIRC, that kills the input to the output tube.  So you will hear no music, just the noise.
Offline bjorgens
Reply #11 on: March 04, 2014, 11:04:34 AM
to ensure I understand, leave the 249KOhm resistor attached but ALSO add a jumper between the same terminals (7U and 10U)?
b
Bryan Jorgensen
First Watt F4 clone
Reply #12 on: March 04, 2014, 11:19:37 AM
Yes, he just wants to separate the driver from the output tube for this test.
Reply #13 on: March 04, 2014, 11:58:18 AM
b
Yup.
Offline bjorgens
Reply #14 on: March 05, 2014, 04:44:33 AM
Ok... Soldered in the jumper, powered back up, and amp is dead quiet with shorting plug in input.  No hiss and no inrush sound on startup either.
Bryan Jorgensen
First Watt F4 clone
