Final check TRS - question [solved]
Hornet900 · 1944
Offline Hornet900
on: March 07, 2014, 09:35:44 AM
success !  ;D
All the Resistance checks and Voltage checks went well ......but which part of the headphone TRS jack do I probe to see if its under 9v
Is it on the underside  or in the inside the plug itself?  :o
I can't wait to hear it now !  the only mistake I made was soldering the updated REVISION part date 5/6/10 wire... I soldered 14L not 14U :)
Can't believe I did it
Thank you
« Last Edit: March 09, 2014, 02:53:02 PM by Caucasian Blackplate »
Austin
Offline Hornet900
Reply #1 on: March 07, 2014, 10:59:44 AM
I found the tip to probe ....its working!
I'm grinning like a cheshire cat
This amp sounds amazing   ;)  you guys know how to make an amplifer!  hats off you you   :)
« Last Edit: March 07, 2014, 01:38:47 PM by Hornet900 »
Austin
