S.E.X start up popping sound
Rayvolution · 2370
Offline Rayvolution
on: March 08, 2014, 03:33:32 PM
I have a S.E.X kit with C4S that I built a few months ago and it was perfect! However in the last week for some strange reason the left channel pops and hisses for the first 30 seconds to a few minutes whenever I turn it on. It doesn't pop or hiss after a little warm up, but the period for which it pops and hisses varies every time. I've switched tubes, headphones, cables, and sources to no avail. Plz help
Offline Zimmer64
    • Blog
Reply #1 on: March 08, 2014, 07:25:46 PM
Have you checked all the solder joints again?
Michael
Offline Rayvolution
Reply #2 on: March 09, 2014, 07:54:25 AM
Yeah I did noticed the 10Kuf 10v capacitor somehow became disconnected on one side but I resoldered it and the noise is still there.
It only pops and sounds like a windstorm when I cold start the s.e.x if I turn it off after some use then turn it back on its fine.
Note: The fuzz/popping occurs even with the volume at 0
« Last Edit: March 09, 2014, 07:59:36 AM by Rayvolution »
Offline saildoctor
Reply #3 on: March 09, 2014, 08:48:01 AM
I had a problem like that once with my Paramounts when I changed the cathode resistors.  I plain old forgot to solder one of the wires crimped to a terminal.  I finally caught it after the third 'thorough check' of my solder joints.   ::)
Kerry Sherwin
45 Paramounts, 6SN7 Extended FPIII, OC3 regulated Seduction
Blumenstein Orca Deluxe / 2x Orca Subs
VPI Classic / ADC CD-100x
