Improvement bypassing volume control?
Paul Folbrecht · 3165
Offline Paul Folbrecht
on: March 09, 2014, 11:07:17 AM
I use my Stereomour with a Placette RVC.  I'm guessing I'd notice a small improvement replacing the volume pot with a resistor.  What would be the specs on the resistor I'd want to use?
And, same question for the selector switch.
Apologies if this has been covered in the forum.  Couldn't find it.  TIA.
Reply #1 on: March 09, 2014, 02:47:17 PM
This is doable.  I don't generally recommend removing the selector switch, however, as it's tough to put back.
If you substitute resistors for the volume control, 50K-249K is a good range.  Wattage rating is unimportant here.
Reply #2 on: March 15, 2014, 06:53:16 AM
Paul, I have a few more questions, if you don't mind (due to my general ignorance about electronics).
- Is the value chosen for the resistor here setting the Zin of the amp?
- If no, why isn't it possible to bypass the pot directly - no resistor?
- The resistor will not attenuate the signal at all, right?  (It is in parallel?)
Reply #3 on: March 15, 2014, 09:12:09 AM
Hello Paul,
Yes, the resistor approximately sets the input impedance of the amp.  There are also input capacitances that should be considered, but very few source components aren't going to be able to handle these.
If you have no resistor, then there is no path to ground for each grid of the 12AT7.  When the tube begins to operate, electrons will hit the grids, and without a path to ground, the tube's operating point will shift all over the place (potentially damaging the tube).  In some circuit designs where the designer is not very trusting of the level control, sometimes you will see an extra resistor from the output of the pot to ground (of a high value, usually 1M) in case the wiper fails.
The resistor won't attenuate the signal, but the output impedance of the preceding stage will be in series with the resistor at the input to the Stereomour.  For example, if you decide that you want a pair of 10K resistors at the input (bad choice), and your source component has an output impedance of 10K, then you will lose half your incoming signal (6 dB).
Typically for a power amplifier, we use 249K resistors at the input.  A preamp with a ~2K output impedance is driving such an amplifier, the loss from the output impedance of the preamp and input impedance of the amplifier will be 20Log(251/249), which is about -0.1dB (tough to hear).
