another Stereomour but a giant step for me
borism · 13949
Offline borism
on: March 13, 2014, 08:06:58 AM
Hi,
I have been reading this forum for a few months and have found it to be a great resource as well as fun to read. My kit arrived about a week ago and I have started working on it. Briefly, I have no experience working on electronics, never have used a soldering iron before and have no woodworking skills to speak of.
However, building my own amplifier was so intriguing that I just had to try. Another disclaimer is that I am well aware that I should be building the original kit but I just could not resist making some substitutions that I have seen mentioned frequently on the forum. Clearly, I am not blaming anybody else particularly when, as possible, I come back for troubleshooting help.
So my upgrades include:
goldpoint selector and stepped attenuator
cardas speaker binding posts
Mundorf coupling, parafeed caps
My main issue so far has been, unexpectedly, the finishing of the woodbase. I didn't like the streaky polyurethane finish, so I ended up sanding it down again and starting over.
(http://)
I hope the images download correctly. If not, I may need some help.
Boris
Boris
Offline Bartguy
Reply #1 on: March 13, 2014, 09:09:00 AM
Boris, I built mine with a Goldpoint attenuator and switch, too. If you need help wiring them, (I did) let me know and I can show you how I did mine. They're working fine.
Reply #2 on: March 13, 2014, 09:16:26 AM
The one step finishes can end up very splotchy and streaky. I recommend using a separate stain and clear coat.
Offline borism
Reply #3 on: March 13, 2014, 02:39:11 PM
Hi Bartguy,
Yes, I think I know the wiring scheme but if you have some pictures or tips it would definitely help.
Doc, I did use a seal coat, then stain followed by polyurethane, but it was just my lack of experience. Now I intend to use shellack spray to see if I can get a smooth finish.
One more photo where things are:
Boris
Offline borism
Reply #4 on: March 13, 2014, 02:44:42 PM
Sorry, let me try again
Boris
Reply #5 on: March 13, 2014, 04:01:33 PM
The key to poly is multiple thin coats, and sand the finish flat between each coat.  The more layers you add the flatter and smoother the finish will become.  I used four coats i mine, using finer grade sandpaper between each layer.
Offline Kris
Reply #6 on: March 13, 2014, 04:18:54 PM
I used wipe-on-poly for wood base. Can't go wrong with this stuff.
Offline JamieMcC
Reply #7 on: March 13, 2014, 09:35:56 PM
Incrementally adding a little oil based varnish to some wipe on Danish oil or Tung oil gives similar results.
Offline borism
Reply #8 on: March 14, 2014, 04:35:32 AM
Thanks for the tips regarding the wood finishing. I was considering a wipe on poly but ended up using the brush. My poor sanding between coats resulted in the corners being stripped of the stain. That's when I ended up sanding it all down to the wood. Has anyone tried a spray on Shellack? Or, maybe going back to some wipe-on finish is safer?
My progress is somewhat slow, in part due to time limitations. Last night I progressed to the first input wire. You'll note that I installed the power board with the 4 resistors replaced by two Mills 270 ohm (seen on this forum for 2A3 tubes) ones. My thought being less must be better. Also, I decided to replace the input wire with a Mogami 2534 quad cable. The ohm-meter was helpful in sorting and marking the wires (there are 2 blue and 2 clear coated ones). Again, I am indebted to this forum for the idea. I only got the input #3 done yesterday.
Boris
Offline JamieMcC
Reply #9 on: March 14, 2014, 05:42:21 AM
I have not tried spraying shellac however I do regularly use automotive clear coat/lacquer on wood and have found it works very well if the wood is dry and well seasoned. You can also use a brush to apply I find if I dip the brush in some thinners first then wipe or spin it out so the bristles are only a little damp from the thinners then dip in the lacquer it flows out nicely.
I did these pieces with the clear earlier in the week.
Reply #10 on: March 14, 2014, 05:50:55 AM
Shellac can make a nice finish, but it is actually rather tricky and tedious to do in the best possible way, which is French Polish. It also makes a good filler over which to shoot nitro lacquer as a finish coat - again a whole lot of work.
My suggestion for a relatively easy and foolproof finish is no stain or a good water based stain and then brush or spray coats of a water based clear poly finish, lightly sanding with 220 grit paper between coats.
I don't use a sealer before staining, but I use a water based aniline dye and the penetration characteristics can be different than with oil based stains.
Reply #11 on: March 14, 2014, 06:00:26 AM
Here is my suggestion for a finish:
Start at the bare wood.  Stain to your liking.  Give it a coat of spray Shellac (I have used this often) making a few light coats, 4/0 steel wool in between coats
The shellac seals the wood keeping it from soaking up a varnish.  Then spray light coats of polyurethane for shine.
« Last Edit: March 31, 2014, 02:59:09 AM by Grainger49 »
Reply #12 on: March 14, 2014, 06:08:48 AM
Sry for going off topic, but what type of wood is the sample on the left?
Offline JamieMcC
Reply #13 on: March 14, 2014, 06:38:25 AM
Hi Mark it's Spalted Beech and can be tricky to find with consistent patternation running through it, its one of my favourites and a bit different from the norm.  You can see wha I am making here as well.
Offline borism
Reply #14 on: March 14, 2014, 07:02:17 AM
Thanks for all the suggestions.
Jamie, the wood looks beautiful. Let me know if you do some work on request.
Grainger, since I already bought a can of spray shellack, I might as well give it a try.
Boris
Boris
