SEX 2.0 C4S Instructions Unclear -- Ground Wiring [solved]
eratosthenes · 1683
Offline eratosthenes
I just installed the C4S upgrade. The instructions that were included were for the 2.1 kit, but I was able to piece together what was needed, or so I thought.
I have the C4S installed along with the new power supply resistors. Voltage at input of the C4S is about 400v. There is almost no voltage on either OA or OB and LEDs aren't lit. Sound output is minimal.
POSSIBLE SOLUTION: I see the 2.1 instructions include a ground attachment. I don't have this implemented (no clear instructions). What's the next step?
« Last Edit: March 15, 2014, 12:01:51 PM by Caucasian Blackplate »
Reply #1 on: March 15, 2014, 09:37:59 AM
PM me your e-mail and I'll send you a download link for the SEX 2.0 manual.
Reply #2 on: March 15, 2014, 09:39:48 AM
Did you get the kit for 2.0 or 2.1? The kits are quite different, the 2.0 has two boards, the 2.1 has one.
Reply #3 on: March 15, 2014, 09:59:25 AM
Yes, I have the 2.0 kit with separate boards. Yes, there is a ground wire that wasn't implemented (as per 2.0 instructions.)
Everything else is set up just fine. No further desoldering needed.
I will have this fixed shortly.
Thanks.
Reply #4 on: March 15, 2014, 11:28:16 AM
Everything is good, now.
The amp is working like it should.
Thanks.
