General Category
General Discussion
top HV contact output tube
josmiceli
1925
josmiceli
Newbie
March 16, 2014, 05:58:27 AM
I bought some 6BG6 GA tubes with the HV contact on top of the tube.
I also bought the appropriate connector for the top. Is there some trick
to soldering the cable to the connector? It looks like it would be hard to
do without doing damage to the housing of the connector. There is
barely enough room to get a soldering iron in there. Any advice is much
appreciated.
Paul Birkeland
Global Moderator
Hero Member
Re: top HV contact output tube
Reply #1 on:
March 16, 2014, 07:46:49 AM
Generally the metal piece comes out of the top cap connector, then you slip the wire through the insulating cover, then into the metal contact, solder, then snap back together.
galyons
Sr. Member
Geary Lyons
Reply #2 on:
March 16, 2014, 08:04:56 AM
What is your plan for them?
Geary
VPI TNT IV/JMW 3D 12+Benz LP-S> Eros + Auralic Aries + ANK Dac 4.1 >Eros TH+ Otari MX5050 IIIB2 > BeePre >Paramount 300B 7N7 > EV Sentry IV-A
Thorens TD124/Ortofon RMG-212/SPU >Seduction > Smash^Up> Paramour 45 MQ >K12's
josmiceli
Newbie
Reply #3 on:
March 16, 2014, 10:05:12 AM
I plan a SE stereo amp, but it's barely in the design stage.
No values, no layout yet. I'm sure I'll be back to the
vast knowledge pool later.
General Category
General Discussion
