Pre Build Question
Guy Boisvert · 2860
Offline Guy Boisvert
on: March 16, 2014, 11:19:51 AM
I'm about to start the Eros kit and am wondering if I could install a "mini chassis"  to the rear of the wooden base. On that chassis, I would put the four RCA Jacks and the phono ground post. The mini chassis would, of course, be grounded/connected to the main chassis.
I would prefer to run my cabling to the rear.
Can't see why this would not work....but safer to ask.
Perhaps I should have posted this on the Eros board ? Anyway, that is my question, whether asked here or elsewhere.
Reply #1 on: March 16, 2014, 11:49:14 AM
You can build the Eros stock, then turn it around 180 degrees to obtain what you're looking for.
I wouldn't recommend running a bunch of cabling under the power transformer.  Shielding and grounding will also become complicated if you move the ground post.  (Especially moving it outside the amplifier chassis)
Reply #2 on: March 16, 2014, 11:59:10 AM
Good advice ! I'm glad I asked.
Thanks Paul
