cleaning & painting sides of transformer
jboehle · 3836
Offline jboehle
on: March 20, 2014, 05:20:59 PM
I got my Crack kit today and the transformer has some goop on the sides that is not so visually attractive.  What can I use to safely clean it off?
Also, is it safe to paint the sides of the transformer?  I would like them to be a glossy black to go with how I am coloring the rest of the amp.
Offline galyons
  • Geary Lyons
Reply #1 on: March 20, 2014, 05:26:10 PM
Yes, you can gently sand down the "goop".  Then you can paint the stacks, but mask off the  bell top and terminals bottom.  I use use Rustoleum  Appliance epoxy paint. Works well.
Cheers,
Geary
Reply #2 on: March 20, 2014, 05:29:10 PM
The goop is what holds the transformer together, so don't take too much off!
Offline jboehle
Reply #3 on: March 20, 2014, 07:56:05 PM
That's why I asked, I didn't want to use some solvent to clean it that would dissolve something important!  Sounds like sanding just the extra goop off the outside should be okay then?  I will tape some plastic over the top & bottom before doing it just so none of it gets inside the transformer.
Offline galyons
  • Geary Lyons
Reply #4 on: March 20, 2014, 08:02:29 PM
No solvent.  Just a light sanding to smooth out the varnish.  I just finished a  Crack. The varnish had major runs & globs.  I used a sanding block to get it mostly even without cutting through to the stacks.
Cheers,
Geary
Reply #5 on: March 20, 2014, 08:29:31 PM
I did mine with a sheet of sandpaper on a pane of glass, the nice flat surface makes it easier to knock off the globs of glue without digging into the laminations. Looks flawless now.
Offline Guy 13
  • Audio should be simple!
Reply #6 on: March 21, 2014, 12:50:04 AM
Cheers,
Geary
Hi Geary.
Are you referring to/talking about MY Crack ?
Guy 13
Rega P3/Exact MM / Rega Apollo / Decware SE84C+ / Bottlehead Crack / Sennheiser HD650 / Grace Mondo RIT/ Omega 7F OB dipole / Double Eminence 12" Acoustinator OB dipole.
Offline jboehle
Reply #7 on: March 21, 2014, 09:55:13 AM
Thanks all, I lightly sanded until smooth to touch, wiped it down with a barely damp rag, then let it dry.  Just finished painting it and now it's drying.  I can still barely see some of the remnants of the goop but hopefully after it dries they will not be noticeable.
Offline galyons
  • Geary Lyons
Reply #8 on: March 21, 2014, 10:12:31 AM
Cheers,
Geary
Hi Geary.
Guy 13
That would be the one!
Cheers,
Geary
Offline Guy 13
Reply #9 on: March 21, 2014, 04:40:18 PM
Cheers,
Geary
Hi Geary.
Guy 13
Cheers,
Geary
Hi Geary.
I should be getting my Crack on April the 11th around 11.30pm,
that the time of arrival of my wife's aunt.
She will also bring with her a 6AS7G RCA with a 12AU7 RCA clear top tunes.
So I will be able to do some tube rolling.
By the time I get back home with the auntie it will probably be around 1.30am,
but I am sure that won't stop me from plug everything and do some listening.
Who knows, I might spen the whole night listening to music.
Guy 13
Sorry for barging in this threat that is not mine.
