leftover battery box wire
jwa · 2737
Offline jwa
on: March 21, 2014, 05:19:13 PM
Hello everyone,
                         My first post here. I have begun working on my Quickie.
 I have discovered that with the Cerebral Palsy in my right hand and leaving extra length for stripping mistakes, that I still had problems with cutting the wire for the battery boxes. I  have ended up cutting the wires almost  too short to join per the instructions.
Also, while stripping them, I have cut into the wire strands. I  am wondering if the soldered  connections will be sound.
With all the preceding out of the way, can I substitute some  22 g. solid copper core wire for the battery box leftovers.
Thank you,
John
Reply #1 on: March 21, 2014, 08:17:52 PM
Hello John,
Sorry to hear of your building troubles. You can wrap any battered insulation with some electrical tape as a precaution, but the voltages in the Quickie are low enough that it's not much of an issue.
22 g solid core wire will work well for the rest of the circuit and be pretty easy to use.
Offline jwa
Reply #2 on: March 26, 2014, 03:00:01 PM
Paul ,
         Thanks for the reply.
        John
